      pulls under accel.
      I haven't looked into the problem yet. My cuda pulls pretty hard to the left under hard acceleration. Stock suspension. I'm thinking a front leaf spring bushing is bad but could it be something else? Something with the posi?
      Oct 2005
      Florida
      My friend has the same problem with his 68 roadrunner, his clutch packs in his rear end are stock and wearing out so when he guns it from a stop both wheels dont spin all the time, thats what we think it might be, im not sure if your rear is the same as his, but it worth a check.
      1969 Chevy Camaro 350-8th cylinder gone =[-
      2005 Dodge Viper SRT-10 505/ 510hp
      Feb 2002
      Springfield, MO
      could be several different things, like bushing(s) bad in rear spring. Bolt loose somewhere. Rear end loose from springs. Carrier bolts loose in center section (happened to me) and causing the pinion to ride up the ring gear and push the car to one side. Broken axle. Or even you turning the steering wheel under acceleration!! LOL!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
