      clutch actuator fitting needed
      I am trying to find the part number or part (if someone has one) for the hydraulic line and fitting the comes off of the clutch actuator and plugs into the line off of the clutch master cylinder for a 2000 firebird/camaro.
      THe clutch actuator is part # 12565145 and the master assembly is 12570277, just need part in the middle!
      The line is not sold seperately. It comes as part of the MC assembly when you purchase it from GM.
      Quote Originally Posted by andrewb70
      I purchased part # 12570277 from GM, but there is only the braided line that comes off the MC, not the hard line, with mating female quick connect fitting, that comes off the actuator?
      The hardline with the female quick connect comes with the actuator. Did yours not come with one?
      I bought the master, but looked at a picture of the actuator and it did not show the line on GMpartsdirect.com
      I have a gto trans and the actuator/hard line has a diffrent fitting then the camaro/firebird! SO I guess I need an actuator assembly also.
      THanks for the info.
