      Jun 2002
      Long Island, NY
      LS6 vs. LS7 clutch spline count
      Does anyone know if the spline count on the LS7 ('06 Z06) clutch is different than that on the LS6 (01+ F-body, C5, etc) clutch? The LS7 clutch is a pretty popular swap for the 4th gen F-bodies since the clutch is reasonably priced and will handle 500RWHP+. Several people have done the swap without isssues; I'm planning on swapping one into my SS next week, but someone recently told me that the spline counts are different on the input shafts and the LS7 clutch won't work with a f-body T56? I believe this to be false, since several peopel have done the swap without issue. Can anyone confirm? I'm planning on ordering the parts tomorrow.
      Parts for swap:
      LS7 Clutch / Pressure Plate
      LS7/LS2 Flywheel
      LS1 T/O Bearing
      LS1 Slave / Master
      Socal, Ca
      You may want to check www.ls1tech.com
      Jun 2002
      Long Island, NY
      Quote Originally Posted by DJW32
      I searched LS1tech, but couldn't find anything on the spline counts. Did get the part numbers and other good info, though.
      Quote Originally Posted by Andrewb70
      They are the same. 1 5/32" (more commonly called 1 1/8") 26 spline.
      Thanks Andrew! Much appreciated, I ordered the stuff today.
      Hey Ralph, so have you sorted out the problem with your clutch/tranny/rear yet? Or are you just buying parts right now?
      I've diagnosed it enough so that I'm almost certain it's not the rear. My Dad's 100% sure that it's something with the clutch, even though I still think it may be the input shaft bearing. I'm going to go with his hunch though, since it's easier for me to change a clutch as opposed to rebuild a tranny. I'll also need the LS7 clutch eventually to handle more power, and if it turns out not to be a clutch problem, I can always blame it on him, haha. If I don't swap the clutch in this Thursday/Friday I will next week. I'll post an update in the forum (hopefully a positive one).
      jp
      ​John Parsons
