      Nov 2003
      Wisconsin in the woods
      98 WS6 Not starting
      Well, long story short I test drove a WS6 Friday night ran fine etc... Went to test drive in the daylight on Sunday and the car won't start. I went over tonight and dropped the starter to check for power on the switched lead to the starter and nothing.
      Where am I headed next is it the neutral safety switch? (automatic by the way) or am I headed to the ignition switch/mod? Easiest place to test? How hard is it to change? What are the better manuals to have to work on this LS1?
      Thanks in advance.
      Brad
      PS Ralph the price I think is dropping pretty good on this car!!!
      Jun 2002
      Long Island, NY
      Brad,
      I'm glad to hear about the price drop. I'm not sure what the problem is with the car, but as for the manuals, I just ordered a Helms manual for mine the other day. Pretty pricey @ $130 or so, but it's real thick with tons of info so hopefully it'll be pretty helpful; it's the same one the techs use. I was holding off for a while on buying one, but I finally broke down and paid the money after dealing with some issues.
      Feb 2006
      NYC NY
      The helms manual has been a life saver for me on countless occasions, you won't be sorry.
      Things to look at, there's a relay on the passneger side behind the kick panel, sometimes it gets kicked or corroded and the car won't start, won't try to crank, lights won't dim, nothing. Does not set of a security code either.
      The wires running by the starter, double check that they haven't been burned by the exhaust, chech two or three times if the car has headers.
      I presume the battery is fine and the car has lights, do they dim when you turn the key? You didn't mention.
      -Jason G-
      94 Pontiac Firebird LT1,T56, 315 x 4
      Mountain View, CA
      Uh engine forum maybe?
      True T.
      My blog
      Orlando
      There is a starter relay in the fuse box attatched to the driver's sideinner fender. Check for switched power there. After that go to the electrical part of the ignition switch on the column, it's on the passenger side of the column about halfway down, you'll have to remove the trim panel that your knees rub when you drive.
      The last thing it could be if the anti-theft system. If everything else checks out and you think it might be the PASS key system, PM me and I'll give you my #, I can talk you through it. Too much to type.
      Chris
      67 Camaro single turbo LSX/T56 -V2.0 underway
      06 AMG CLS55 2.9 Whipple, 5.6 forged Darton MID
      06 AMG E55 w 63 conversion 2.9 Whipple
      99 FRC Corvette pretty in pink
