Thread: 98 WS6 Not starting
- Feb 2006
- NYC NY
- 35
The helms manual has been a life saver for me on countless occasions, you won't be sorry.
Things to look at, there's a relay on the passneger side behind the kick panel, sometimes it gets kicked or corroded and the car won't start, won't try to crank, lights won't dim, nothing. Does not set of a security code either.
The wires running by the starter, double check that they haven't been burned by the exhaust, chech two or three times if the car has headers.
I presume the battery is fine and the car has lights, do they dim when you turn the key? You didn't mention.
-Jason G-
94 Pontiac Firebird LT1,T56, 315 x 4
