Thread: Desktop Dyno Help
02-14-2006 #1
New to Pro-Touring
- Nov 2004
- 78
Desktop Dyno Help
Hey guys, I was fooling around on Desktop Dyno 2000 today. I put together a little combo for my BBC 396 (402=.30 over) Here is a pic, the HP is pretty high up, how would i bring it down and get it closer to the torque curve. Basically what should I change to refine this set up? Note-- I didn't know the specs on the comp cams cam I used, so I found a sample spec sheet with some numbers on it and plugged those in at the bottom. Thanks for any help.
Get Blended
02-14-2006 #21. Bump the compression up- it'll be fine with 9.5 and those heads. I'm assuming pump gas...
2. Run a wider LSA, to the tune of 110-112, with more lift. Look for something in the .550" range (with stock 1.75 rockers).
3. Spec out a HP 830 carb. DD doesn't have the ability to plug & play different booster or jet combos, but the 750 won't offer you the responsiveness of an 830/850. Hell- I've got a buddy that has an Edelbrock Qjet copy on a 402 that runs real nice.
4. Even though DD will show different peak power #s, the performer RPM does real well on street 402s.
A real good dyno tune will put the power where it needs to be.
02-14-2006 #3
New to Pro-Touring
- Nov 2004
- 78
Hey I'll try that. Thanks for the help. I didn't even notice that it was at 8:1 compression....STUPID ME
Thanks againGet Blended
02-14-2006 #4
