Results 21 to 40 of 47
Thread: Overall LSX experiance?
02-17-2006 #21
Do the ls1, I did! I can talk all day long on how the LS1 is a better motor then any previous SBC. Hands down, you cant go wrong. There is nothing bad about them! Think about it.
To bad you are not local, I would happily tune your car!
Twin Turbo Ls1 '71 Chevelle
93 octane 1000 hp street car!!
02-17-2006 #22
- Aug 2004
- 341
If you want good mpg go with a 6spd. It's easier to install (wiring), work on, lighter and there is no replacement for banging gears!
Really I put my ls1 when I was 19 working at Costco, and it was a bitch both in time and the dent it put it my wallet. Trust me when your in the middle of installing it you will ask your self why, but trust me stay the course it's worth it. It's a good feeling when you dyno your car and it put 350 to wheels stock and it raises the car even though you put in lowering spring because it's so light.
The only advice that I would give you is this.
Don't buy anything from S&P, I bought there motor mount adapter plates, oil pan and headers. Why? Because they were the only company that was offering products that I needed. There motor mount adapter plates aren’t bad and move the engine back a little which is good (compared to BRP mounts which move it forward). ATS has motor mount adapter plates that come with poly mounts (S&P don’t come with anything) ok for me because I run solid mounts. There oil pan is crap, it’s a modified version of a stock f-body pan but they remove the baffling on top, once I find a buyer for my pan I’m buying an ATS pan. The headers are crap too, when I got them in the mail I took them out of the box saw them, then mailed them back. I ended up buying 4th gen f-body headers, pacesetters and modifying those then made my own x-pipe and exhaust. Hooker now sells ls1 swap headers.
Intake is easy, just find a shop that works on diesel trucks and get a 90 degree 4in. mandrel bent exhaust pipe and rout it into your fender.
You radiator needs to be modified can’t forget that vapor line that comes off the head.
Take time with your wiring make sure everything is grounded correctly.
Set aside 400-500 dollars for a good dyno tune (no mail order crap) after the install, worth every penny.
If you want performance order stuff from ATS www.t56kit.com. This would include tranny cross member, clutch master and everything needed. If you like chrome go to the many other companies.
You’re in Livermore, my parents live in San Ramon, PM me if you want me cell number I would be more then happy to help you out with the install/ show you my car.Stuart Seitz
03-06-2006 #23
- Aug 2004
- 63
The guys at Street & Performance are always ready to assist with any questions and put out a quality product. They've done plenty of projects without a windage tray. It doesn't seem to effect them. What are you worried about unless your cornering really hard.
69 Camaro w/LS1.
Start date April 2002, completion date June 2013. But it will be well worth it!
03-06-2006 #24
