    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 75
      Nov 2001
      Sacramento Ca
      **Pro-touring.com needs your help** (everyone please read)
      We are revamping The pro-touring.com official wheel fitment database
      We need all of you who've fitted custom wheels and tires on your car to post up all the usefull info you have.
      Please see the database to see what we're after.
      we're going to be adding a mini tubbed/not mini tubbed column as well.
      Please post your car's info right here in the thread so i can enter it.
      thank you all in advance.
      Tony Langlois
      1966 Corvair Monza
      Welland, Canada
      Wheel info
      '69 Camaro non tubbed
      Front 245/45/17 8 in rim 4.75 bs- Baer disc-QA1 coilovers- stock sub
      Rear 285/40/17 9.5 in rim 5.5 bs- Baer disc-Hotchkis 1.5 in drop leafs- lips rolled
      HTH
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      Sep 2001
      Accord, NY
      69 camaro vert, not tubbed. GW coils (1.5" drop), Hotchkis rear leafs, C4 13" front/rear drum.
      Vinatage Wheel Works V45 16x8, 4.5 BS. 245/50/16 F, 255/50/16 R. No issues.
      68 camaro - SOLD
      Woodbine, MD
      88 monte carlo ss...2" drop spindles, 2" rear drop springs..no issues
      front 16x7 4"bs 225/50/16
      front 17x8 4"bs 225/45/17
      front 17x8 4"bs 245/45/17
      rear is being mini-tubbed soon...will have those measurements asap.
      Newbury Park, CA
      '68 Camaro. Non-tubbed, rolled rear fenderlips, short steering arms, steering limits, tubular A-arms
      F/R 275-40-17 @ 17 x 9.5 x 5.5 bs Vintage Wheelworks V45
      Bayou Country, LA
      '69 Camaro
      Front - 17x8
      BS - 4.75 inch
      Tire - 235/40/17
      Rear - 17x9.5
      BS - 5.5 inch
      Tire - 275/40/17
      Front Springs
      Moog part # CS6312
      One full coil removed
      Rear Springs
      Hotchkis Part # HSS-2407C
      American Racing TT II's
      East Coast Florida
      '68 Firebird
      Front-17x8
      B.S.-4.5 inch
      0.5 inch mounting pad for Wilwood brakes
      Tire - 245/40/17
      Martz Road Race
      2" Drop Spindle
      Rear-17x13
      B.S.-6.0 inch
      Tire - 335/35/17
      DSE Mini-Tubbed
      Rolled Rear Fenderlip
      QuadraLink Rear
      Project "Freebird"
      Red Deer, Alberta, Canada
      72 Chevelle:
      2002 GM ZQ8 S10 wheels. 16x8, 5 x 4.75" Backspacing: 4.25"
      255/50/16 rubber mounted on them and on all 4 corners.
      -Matt
      Matt
      Instagram: Cst_koon
      Jul 2002
      Mesquite, TX
      69 El Camino. Not tubbed, stock suspension (for now).
      17x9, 5" backspace (Cragar Soft 8s) with 275/40-17 tires on all four wheels.
      Eastern Virginia
      86 Monte Carlo SS
      Front: 17X8", 4" backspacing (I think), maybe 4.5", 245/45/17 tires.
      Rear: 17X9.5", 5" backspacing, 275/40/17 tires.
      Rear suspension: BMR tubular control arms, Poly bushings. 1" drop springs.
      Front suspension: 98-02 ZQ8 spindles, 13" Vette calipers & rotors. TRW S-10 springs. F body 1LE 36mm sway bar.
      Scot
      Scot
      86 Monte SS
      St George Utah
      We just did a 69 Camaro
      Non tubed
      20X10 with 5.5 BS on the rear 275/35/20 Pirelli ( tires are too narrow for the rim could fit a 275/35/20 BFG KDW couls also have a 6" BS and then possibly fit the 285/30/20 KDW with minor fender trimming
      18 x 8.5 with 4.5 BS.......... not exactly sure on the bs of the front
      3" mini tub
      20 x 12 5" BS rear end is 53 3/4 wide ( 335/30/20 ) with this rear end width we will be using a 1/2 wheel spacer, i like to order the rear a little narrow and adjust the look and fit with spacers.
      19 x 8 with 4.75 BS and 245/35/19 ( could be 5.25 BS to give just a little more clearance on the fender lip
      Grand Haven, MI
      1969 Camaro, No mini-tub
      Front:
      17x8 Eagle Alloys series 211, 5" backspacing, 245/45-17, cut coils
      Rear:
      17x8 Eagle Alloys series 211, 5" backspacing, 275/40-17, de-arched leafs
      La La Land, CA
      A client's 68 Camaro-
      Non tubbed, roller fender lips
      Fiske Profil 5 rims
      Front 17x8 with 4.75" of BS with a 245/45/YR/17 BF Goodrich G-Force KD tires
      Rear 17x9.5 with 5.615" of BS with a 274/40/YR/17 BF Goodrich G-Force KD tires
      Tyler
      Fullerton, CA.
      1971 Chevelle
      Fronts: 16X8 Edelbrock 409, 4.5" backspace w-245/50-16 Falken Z502
      Eibach springs, 1-3/8" sway bar, Bilstein shocks,
      Stock A-arms.
      Baer track 13" brakes
      Rear: 16X8 Edelelbrock 409 wheels, 4.5 backspace w-255/50-16 Falken Z502
      Eibach Spings, global west upper and lower trailing arms and braces.
      Bilstein shocks 1" rear sway bar,w-Baer serios street 11.35" brakes
      Set up works great W-No interference
      Quote Originally Posted by killer69
      Non tubed
      3" mini tub
      What front suspension are you using?
      Jim
      72 Nova
      Front Centerline 18x8 stingray III wheels 5 inch back space. 245-40 tires. Hotchkis 2 inch drop coils Helwig 1 1/8 sway No inner fenders but should clear.
      Rear.. Same rims with 255-45 tires. Hotchkis leafs All suspension parts in stock location.
      Bilsteins on all 4
      Boonville, Missouri
      '73 Challenger - Non Tubbed
      Front 17 X 8 Hot Wheels Model 68 4.5" back spacing 235/45/17 Fuzion ZRI
      Rear 17 x 9 Hot Wheels Model 68 5.0" back spacing 275/40/17 Fuzion ZRI
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Chesterfield Twp, MI.
      1971 Nova SS Clone
      Front:
      17X7 TTII's, 4" B/S
      235/45/17 BF Goodrich G-Force tires
      DSE drop coils with 1 coil cut off
      Equates to 3" drop in the front.
      Rear:
      17X9.5 TTII's with 4.5" B/S
      275/40/17 BF Goodrich G-Force tires
      DSE 2" drop leaf's
      Stock fenderwells front and rear, stock shock locations (lower rear mounting point modified). Edelbrock IAS Shocks (Cylinder on top, plunger on bottom, better clearance to the leaf springs). Rear axle narrowed 1 7/8" on each side (wanted the deep dish look on a Nova). No tubbing issues on the rear, rubbing on the front at the inner fender on full lock.
      Steve
      Steve
      Jun 2002
      Benicia, CA
      71 Camaro
      Front: 19x10 CCW SP16's, 275/35/19's, 7.25" bs, tire edge about 1" from outer fender lip edge. Vette Brakes transverse spring setup with upper and lower control arms. GW Del-a-lums in control arms, offset the shafts a bit to get more caster. Bilsteins. Will use ATS AFX spindles and whatever killer front brake setup ATS sets me up with. Herb Adams 1.31" sway bar.
      Rear: 19x13 CCW SP16's, 345/30/19's, 9.625" bs, tire edge about 1" from outer fender lip edge. Vette Brakes 200# rear leafs. Minitubbed about 4" with leafs moved inward, and frame notched. Rear leaf sliders. Bilsteins. C5 front calipers/rotors on the rear. Herb Adams 1" sway bar.
      Jeff
      1971 RS Camaro: PAINKILLER
      Manchester, Connecticut
      I found a chevelle site that has a good format for type of thing. Here is the link. Maybe you can get some idea's.
      http://www.chevellestuff.com/index.htm
      Click on: Tire and wheel combinations ~ What fits what? link on the bottom of the page.
      :3gears: Rob Jones Project "Wild Goat"
