    Results 1 to 10 of 10
      United Kingdom
      Replacement Turn Key Engine
      My 305cu Chev is tired and needs a rebuild, which aint cheap in the UK and for the same price I could buy this...
      eBay Crate Engine
      Any comments/suggestions? Shipping won't work out to much, since I'm coming to the US next month to buy and Astro van, load it up with parts and container it back to the UK.
      1979 Oldsmobile Cutlass Supreme
      Proposed mods; supercharged 350cu in Chevy, 18"/20" Billet rims, rear disc conversion, stripped interior, Dakota Digital guages.
      Aug 2001
      Wilton, CA. (Sacramento)
      Remember that you don't get something for nothing. The HP quotes are via desktop dyno, not a real dyno so your results will likely be less.
      They may be fine builders, the big deal is they're a long way from you if there is a problem.
      Jody
      Dec 2000
      NE Florida
      Have you looked at Scoggin Dickey or Pace Performance? They are GM's biggest crate motors dealers & have many different levels.
      United Kingdom
      Quote Originally Posted by OHCbird
      OK, I'm looking at this kit, GM Goodwrench plus 'kit'...
      Scoggin Dickey GM Goodwrench 'kit'
      What other parts do I need to make it 'turn key' like the one on eBay. HP quoted from the stock 350 is 250HP, so what would I need to change/replace to get it up in the mid 300's? Please forgive, but I'm no engine expert, however collectively with my friends who have more mechanical knowledge I will be able to swap this into my Cutlass.
      Columbia SC
      Check out the 350 HO deluxe package. Its closer to your HP range and pretty much turnkey.
      " I've got an idea--an idea so smart that my head would explode if I even began to know what I'm talking about."--- P. Griffin
      http://www.nastyz28.com/forum/galler...0&way=&cat=500
      http://www.primergarage.com/display_car.php?id=27
      United Kingdom
      Quote Originally Posted by Analog-kid
      I must be dumb, since I can't see that option in any of the crate engines. Where should I be looking?
      Aug 2003
      Prescott Valley, AZ
      United Kingdom
      LOL, no that's the link I orginally put up, I was referring to Analog-kid suggestions of the 'turn key' HO deluxe package?
      Columbia SC
      Summit racing has them. I'm sure other sources for GM Performance parts can look it up. A little more expensive than the other package but the HP # are better.
      http://store.summitracing.com/partde...5&autoview=sku
      GM Parts Direct
      http://www.gmpartsdirect.com/perform...s/frameset.cfm
      United Kingdom
      GM Parts Direct
      Thanks, I was looking within the Scoggin Dickey site, no wonder I couldn't find it. Liking the looks of the GM Parts direct lump, reckon with the aid of eBay I could get it up to turn key for around the same as that 350 I first posted.
      Cheers for the help, more q's may follow!
