    Results 1 to 13 of 13
    Thread: t56 in a cuda
      t56 in a cuda
      Anyone done this swap? If it fits without tunnel surgery, I wonder if an LA to SBC adapter and custom length input shaft would allow this to work. I'm absolutely sure I'm not the first to ponder this question, but I can't seem to find any threads on it. Any thoughts would be appreciated.
      Boonville, Missouri
      I'd give the guys at Keisler a call...I imagine a little surgery may be needed. I'll assume you are doing an E-body Cuda, the shifter location is locate farther way back to that of the GM applications so mods are needed. Cost - I though I saw somewhere around 4500.00. Good luck
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Fort Worth, TX
      I *THINK* I've heard that if you're using a GM-based T56, you may be able to use some sort of adapter bell housing / scattershield that would mate a Muncie to SBM. Here's a thread on Moparts.com that discusses a "cheap Tremec 600" install. Not exactly the same, since I'm pretty sure the T56 is a bit beefire than the Tremec 600, but the business end ought to be the same. In cheapa$$ Mopar fashion, there has been a lot of work put in to getting around the $3-4K cost of admission to a Keisler swap. Not a bad setup at all if you've got the means, though. I'm looking at using a Toyota Supra Turbo R-154 5-speed for my swap, but that's a WAY back burner project.
      Clair
      Maryland
      I'm pretty sure the tko600 is tougher then a t56,and it will fit in the cudas tunnel.the t56 is BIG,just built a tunnel for a freind with a t56 conversion,which wasn't a cuda,but could not get over how much space it took,and how big the tunnel had to be to cover it.If you don't want to cut alot on the car your probably better staying with the tko
      As for Keisler, I've not heard good things about them with respect to the wait time for kits and customer service. I have no personal experience with them, of course, but several different people on different boards have had very negative experiences. That, along with the enormous cost of the kit, preclude them as an option. When a fresh trans can be had for less than $2K, the rest of the kit should not be an additional $2500+. I don't believe that much engineering has gone into it to make it worth that much to me. I would add the caveat that I've never personally seen their stuff. Some have said the quality is very good, so I suppose it's the best on the market, but I can't look at my kid and be comfortable with spending that much dough on something I can do for probably half of that myself with some patience. If I can't make it work for less than $3K, then I'll just have to suck my thumb.
      I think I would rather have a TKO than a T56. I thought of the T56 primarily because they seem to be abundant and relatively inexpensive. I have one in my 69 camaro and love it, but sixth gear is mostly useless because of the ratios. If anyone knows of a supplier who can provide an adapter to mate the TKO to a mopar block, please let me know. McLeod, maybe? If Keisler would sell a bellhousing or adapter only for not too much money, I would give them a serious look.
      Is this not a bellhousing for Chryslers?
      http://www.keislerauto.com/mopar/tra...ellhousing.asp
      Boonville, Missouri
      Here's my 2 cents on Keisler, and I'll admit that I have been and am a sore in Shafi Keisler's side. The TKO 500 and TKO 600 Trans are modified to "fit" the particular Mopar application, meaning the shifter is located in the right spot. This is important when you are using the stock console and other items. The "fit" portion depends on your vehicle. They told me that they can't control the floor board variation through the years, thus I had to put a hole in my floor board to accomodate the trans. Needless to say I was pissed, the kit I had purchased was a "perfect fit" series (no cutting, knotching, hacking...anything) and I let him know about it on the Power Tour 2004 that the Perfect was Not-So-Perfect. The bad part was the time of delivery of the items, 4 months was and is way to long.
      As far as the trans swap....now that I am done and have some miles on it, I like it, it performs well and has handled everything I have thrown at it. If I had to do it again, I'd have a lift. The quality of all the parts is excellent and the mount is structurally a tank (which is okay) and all the components to get my car on the road were included, even the speedo cable. All the details are covered.
      Bellhousing - Kiesler modifies the stock bell housings and Lakewood Cans. I had them modify my Lakewood. Costs an extra $50.00. Call Mcleod they may have a bell housing now.
      For all reading, I'm not bashing or praising. Keisler is the only one that has developed kits for Mopars. Trust me when I say the TKO trans. is modified for the correct shifter location on an e-body. The cost of having an "engineered" system to the problems of doing a custom one-off yourself may outway itself. You can pick your battles cause cheap isn't always better.
      Tony Edler
      Illumin8s
      Maryland
      The tko is made to take the place of a muncie,it is the same depth and bolt pattern as a muncie.I know lakewood makes a smallblock mopar to muncie blowproof,so if the tko is the same as a muncie i don't know why you couldn't use that bellhousing a 26 spline clutch disc and a $1300 tko.Providing you are running a smallblock and don't mind moving the shifter hole forward.I don't know if keisler will sell there cross member or there shifter relocator,if so you probably would be saving your self a good bit
      Encinitas, CA
      Cudman-
      Give me a call - we have been toying with the idea of coming out with kits for the Mopars as we have been receiving quite a few requests for them. We are officed with McLeod and Red (owner of McLeod) has been asking us to put together a Mopar kit so I know that McLeod is intersted in seeing this happen.
      After speaking with you for a few minutes on the phone, I will be able to let you what will be involved and whether or not we can help.
      We have created kits for many Chevy and Pontiac models - Mopar just may be next.
      Jeff Mortenson
      Andrew,
      Yes, the bellhousing is for mopars. If I read it correctly, however, it's only sold to those who have already purchased or are currently purchasing their transmission, which sort of defeats the purpose.
      Jeff,
      I will be calling. Thanks for the reply.
      Hemicuda
      I thought someone made that part, although I thought it was McLeod. Good to hear Lakewood offers it, also.
      Tony,
      I agree that it is a very nice option if you're willing to spend the money. I could spend the money if I really wanted to, but I just won't. It would be a little irresponsible on my part with respect to my family and I've had good success in the past by fabricating and researching parts myself in order to come up with sound solutions that I think are reasonably priced.
      Maryland
      The Lakewood Bellhousing,jeg's Part#620-77-325 Lists For $221,its Almost Not Worth The Trouble To Make An Adapter For That.when I Start Adding Up The Hours Of All The Adapters I've Made Thru The Years,maybe Its Age,but,sometimes Your Better Off Just Buying The Part
      Boonville, Missouri
      I understand the wanting to save a few bucks...But here are the things that you have to consider. Most of us say our time is free, right. We can never recoup the money that we stick into our rides by building the custom touches...or "personalization" as I like to call it. Place a value on the time you install, remove, re-install, remove (curse), make mods.
      Here's the skinny.
      Tremac 500 - 1819.00 Jegs
      Bellhousing - Lakewood - 212.00 Jegs
      Clutch - estimate 300.00
      Roller pilot bearing for a Mopar - 50.00 - Keisler
      Drive Shaft Mods with Balancing - 125.00
      Speedo cable - 100.00 - Keisler
      Tranny Mount - Custom - 100.00
      GM Sycromesh Fluid - 2 quarts - 25.00
      Clutch Alignment Tool - 26 spline - 5.00
      Total - 2736.00 Without your time for custom fabricating. No tax - No Freight
      Personally - I admire your wanting to custom fab this stuff. Let me know, I'll send you the template for your transmount.
      Tony
      Southern California / Maryland
      The T-56 WILL NOT FIT without some hacking... in the quote above dont borget hardware, the new slipyoke, flywheel, shift handle, trans bushing, (I used my original trans crossmember and modified it)
      I did not like the Keisler service so i went to Darkhorse Performance instead. The kit was pretty good - still had to modify the floor but I was going to do that anyway.
