      Bend, OR
      Rear QA1 coil-overs, or Hotchkis leafs?
      I'm trying to determine if qa1 rear coil-over shocks will work well with stock mono leaf springs. What are the positives and negatives of that combo? I would like to purchase either the qa1 rear coil-overs or Hotchkis leafs. Can't figure out what is the best.
      I currently have air shocks with mono leafs and I can't afford to upgrade both because I'm also installing a Ford 9" (expensive). I would like to find a good compromise.
      Thanks ahead of time.
      Why would you run coilovers with leafs? Just get a good set of shocks and your good to go.
      Bend, OR
      do I need to have leafs at all if I get coil-overs? What's better for street use: coil-overs or shocks and leafs?
      Jul 2002
      Mesquite, TX
      If you get rid of the leafs, you'd need to do something to locate the rear axle - be it a 4 link or 3 link or ladder bars - otherwise those coilovers aren't going to do a very good job of holding the car up.
      If you weren't planning on doing anything extreme with the rear suspension on your car, just go ahead and get a nice set of shocks like Andrew suggested.
      Jul 2002
      Muskegon, MI
      Just like they said. If you get a good set of shocks you will be happy. You dont need the QA1 "coil overs" unless you have 3 or 4 link suspension. If you want QA1 you can get their 12 way adjustable shocks. I just bought them and I cant wait to put them on. Here are the ones I just bought.
