2 Days Ago #1
- Jan 2022
- 104
Suspension Setup Strategy for Increasing Speed
Howdy fellers. I have a couple questions regarding suspension setup theory in relation to down-track feel.
Reading about the conventional vs modern strategies for cornering is really really fascinating to me. Something I've been trying to do is place my car into one of those buckets to figure out from the kinematics perspective what my car is good at and what its lacking so that I can tailor my driving differently to go faster around autocross since that's what I built this car for.
The more and more advanced I get into racing, the more often I hear the words "Sway bars make you slower" and I'm trying to wrap my head around this in a way that can be applicable to my car. In my trial-and-error of trying stuff, a huge amount of my knowledge is from making HUGE changes to learn what happens at the extreme, to then dial it back. Thinking about it, if sway bars make me slow, does this mean the ideal suspension for nuclear speed is not using sway bars at all? This specific question is rhetorical just to get my brain blood flowing.
The first problem is I don't have the theoretical and book knowledge to determine exactly what "Sway bars make you slower" means from a on-paper sense (general understanding but not detailed reasoning); all of my knowledge is "seat of the pants" so to speak, down-track, in this specific car which is a VASTLY different perspective than other cars that are comparably fast or faster. The actual number of "FAST" chevelles around autocross is so astronomically small so I don't really have many (any) people I can creep on to "copy" their setups, and even the guys that do have 3 links have different goals with their cars so I can't even creep on theirs regardless lol
The chevelle platform suffers from many things, all of that aside I've built what is VERY quick chevelle that has mended MUCH of what makes it slow. It has a very manageable and predictable amount of body roll/weight transfer right now. The front is pretty well dialed in (750lb/in spring and I *think* a 1000lb/in sway bar spec-ed by ABC performance so I trust Tony)....out back I built a 3 link/panhard setup with a significantly lower roll center than the 4-link. I've managed to match the weight transfer out back to match the front decently well but with a bigger sway bar instead of different spring rates. 225lb/in spring and a 1100lb/in sway bar. Onto the next point.
The second problem is, I really like how my car handles in cornering right now EVEN THOUGH I technically am potentially leaving time on the table with a massive sway bar.
If I go to ridetech's or QA1 or anyone's spring-rate calculator and I plug in pick-up point values of my current setup, I get a "recommended rate" of between 200-250lb/in, which for a while perplexed me. After idle pondering, that's because those calculators ONLY factor the squat/lift force axis of movement, they DO NOT factor in roll center height and bar rates for cornering rates.
So, I guess this can potentially be a downside of the 3 link; if the "optimal" cornering spring rate is significantly higher than the "optimal" accel/decel rate. Or maybe I'm overthinking it, who knows.
So this leads to my questions.
(These are NOT questions for chevelle owners even though this is a chevelle; I'm looking for answers from folks with the numbers/theory knowledge to possibly point me in the a direction I can explore further. Now, enough of me being a snooty a-hole)
1: If a car has Xlb/in of rate in cornering (sway bar added to spring rate), what is the ideal ratio of spring-to-bar rate in the rear in cornering?
2: If I reconfigure my setup to utilize that preferrable ratio of spring:bar, does the car act *significantly* differently in accel/decel compared to the soft spring/big bar?
3: If a car has a non-ideal bar/spring rate ratio, WHERE EXACTLY down-track would I benefit from going to a stiffer spring/lighter bar; IE what kind of corner on a road course or what kind of element in autocross?
4: Using my numbers, 550lb/in (half of sway bar) and 225lb/in from spring gives me 775lb/in total at 1 wheel; would I use that number as the general guide for selecting new parts? (Example, I have a 440lb/in bar in the garage, could I get 500lb/in springs to come close to that 775lb/in, or is this reasoning flawed?)
