      Southern California / Maryland
      Tremec electric speed hookup
      This is probably been covered but hey I'm new... i have an autometer electric speedo and a tremec 3550 tranmission.... the rear of my speedo has the following 4 hook ups....
      1) Sig.
      2) Out
      3) +12v
      4) GND
      So my question is....
      #3 gets 12v
      #4 gets a ground
      What about #1 & #2 ? Is this where the two wires connect to the electric speedo already in place in the Tremec Transmission ? If so does the wire matter ? There is a yellow and a green wire on the pigtail... it is off of a 88 or 89 Ford
      RT
      Go to this site and find your gauge. Then download the instructions.
      http://www.autometer.com/tech_instructions.aspx?sid=7
      I have my instructions... it shows one wire on the sender to ground and one to the "SIG" pickup... then the "OUT" goes to PCM/Computer... my car does not hae a computer so thats why i asked the question....
      Pittsboro, NC
      It will go to the SIG. IF you hookup to the out, the Electric speedo will not read or register properly. It will not hurt the speedo if you hooked it up wrong. It just won't work correctly.
      Ok - so what you are telling me is one wire will go to the "SIG" terminal and the other wire goes to ground ?
      Pin#1 gets the signal from your transmission's VSS. Pin#2 is not connected to anything if you do not have a stock ECU that requires a VSS signal.
