    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 50 of 50
    Thread: 1970 GTO Judge
    1. #41
      Thanks Andrew I will have a look.
    2. #42
      Grrrrrr. Went to put the new tires and wheels on yesterday, only to find that one of the wheels they sent are a 4.5 ford lug pattern. Hope they help me out because I already threw away the boxes and have the tires mounted.
    3. #43
      Quote Originally Posted by gtome View Post
      That's a bummer.
    4. #44
      They took care of me, but I'm waiting who knows how long for the new wheel. No real biggy since I haven't done much to the car lately. I'm working on finishing up the bodywork so I can get it in color. I hope to order the suspension and rear end soon in case that takes forever to get too. Really need to get moving forward.
    5. #45
      Finally got my engine out of the corvette. I'd like to get the swap kit ordered and I'm planning on using the Holley system. I see they show 2 options, standard location, and forward location. How do I know which one i need? I'm planning on a mid length cast header (for extra ground clearance) and a TKX transmission.
    6. #46
      I would use the forward mounts as that will give you a little more in the transmission tunnel.
    7. #47
      Thanks brother. I kept the corvette fan in hopes of using it on a different radiator. As long as there is room for that I will be happy.
    8. #48
      I got the LS3 dropped in on the forward holley mounts finally. With the stock accessory drive, everything clears so I can keep that if I want, but it is ugly.
      Is there any reason I can't use the radiator out of the 2012 vette in my gto? Besides the ugly factor. I would have to make some custom brackets, but it apparently cooled that engine just fine in the vette.Name:  20250711_154238.jpg
Size:  397.9 KBName:  20250712_110933.jpg
    9. #49
      Mountain Springs, Texas
      Pretty sure that is a brushless fan so it will require some sort of pwm control. If you are using Holley Terminator EFI Andrew can set you up with the necessary PWM control signal.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    10. #50
      I will be using a terminator for sure.
