Results 1 to 20 of 34
Thread: Who is a cam expert here?
HI,
I have a camshaft in my 418 stroker that I've never known the specs. its a custom grind, so I also can't just look up a part number. So I got out the degree wheel and as best I can tell here are the specs I came up with
intake lift 0.646 intake duration 325 intake duration @.050 249.6 exhaust lift 0.6494 exhaust duration 320 exhaust duration @.050 257.5 LSA 111.525 overlap 99.45 intake centerline 111.8
this may not be 100% perfect, but it should be pretty close.
This engine ran well and pulled pretty hard all the way to 7000 rpms. it made 449 whp @ 6020 rpm and 420ft-lb @5240 rpm on a dynojet. this was through a T56 magnum and ford 9 in with 315 wide rear tires.
I always thought this engine should have made a little more power since it was supposed to be around 600 crank. Now that I have an idea what the cam specs are, it seems like the cam has quite a bit of duration and lift. although the LSA is on the narrow side, so I'm not sure how that affects the power characteristics. but I'm thinking it should make decent power in a stroker motor. Does anyone know if there is a better cam that would make a little more top end power and maybe be better suited for a track car?Zach
