    Results 1 to 20 of 26
      Harriman, Tennessee
      Ridetech SA/LA Foxbody Mustang Front Suspension
      I was looking at the ridetech Short Arm/Long Arm front suspension set up and noticed how short the upper arm is. It seems to me this should cause some pretty aggressive camber changes. Has anyone used the system? Thoughts?
      Thanks!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Nov 2016
      Sulphur, La
      Super short shock too. All the other SLA FOX systems have a much larger stroke.
      Houston, TX
      I was excited, until I saw the $3k plus price tag.
      Tu Ho
      Firebird V2-LS swap
      Feb 2013
      Quote Originally Posted by CSG View Post
      Short shock, yes. But it's all about the motion ratio. We still have plenty of wheel travel availalbe. The cars ride and handle unlike any other Fox body I've ever been in.
      Quote Originally Posted by rickpaw View Post
      A little expensive but it's fairly pricey to manufacture. It's pretty competitively priced with other SLA kits out there. There's alot that goes into this setup.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Houston, TX
      Quote Originally Posted by Josh@ridetech View Post
      Josh,
      I'm not questioning the cost - no doubt there is a lot involved. It's just out of my price range at the moment. Guess I just stick with the stock type set up for now.
      Tu Ho
      Firebird V2-LS swap
      Nov 2016
      Sulphur, La
      Josh,
      Would you care to list some geometry numbers?
      Track Width?
      Roll Center height & at what ride height?
      Camber curve?
      Ackerman?
      Castor range?
      Anti Dive percentage?
      Wheel travel?
      Feb 2013
      Josh,
      Track Width?
      Camber curve?
      Ackerman?
      Castor range?
      Wheel travel?
      Hey! Here you go:
      Track width matches fox width within about 1/8”. (Similar to fitment of 94/95 spindles)
      Roll center is about 2.0” at a ride height of 1.5”- 2” lower than stock.
      Camber gain is about 1.3 degrees negative per inch of compression.
      Ackerman is about 30%
      Caster is designed around 8 degrees
      Anti dive is similar to stock at about 30%
      Wheel travel is about 5.5” total
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Feb 2013
      Josh,
      I totally understand! Just let me know if I can ever help out!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Nov 2016
      Sulphur, La
      Hey! Here you go:
      Thanks.
      What about max tire size? I would think you may could squeeze a bit more up there than normal because the spring being in the way is typically a limiting factor.
      Michigan
      Hey! Here you go:
      Thank you sharing real information rather than the usual high-level marketing fluff. Respect.
      I think you guys did a nice job given the constraints of the platform.
      - Ryan
      Nov 2016
      Sulphur, La
      Still interested in tire size as asked above but also wondering what the plans are for the rear? Torque Arm market is saturated. I would like to see a version of the old EVM 3 Link or even the original (not phase 2) of the Steeda 5 link. I've pretty much ran it all and the 3 link was a nice setup that packaged pretty well and still allowed tail pipes. The original 5 link setup does not allow tail pipes. The TA works great except for a bit of brake hop.
      I've run MM, Griggs, etc. front setups along with a Bart's Works SLA. Have not tried the Griggs SLA but have been eyeing it for my current coupe. The ridetech one will now be an option as well.
      Feb 2013
      Our test car currently has 255/35-18's tucking in the fender, it's super low right now. We've had 275's on the front with zero issues as well (we just didn't have it set up quite as low then).
      It's not a real big secret now that we've had our race build out at a few shows as a little bit of a teaser so I can post this now I suppose. I can't give all the details but the rear is a full tubular/very stout IRS that is the proper width for a Fox and has geometry that makes an 03/04 Cobra IRS feel like you're driving a dump truck. As far as tail pipes go on this one, we're using an off the shelf Cobra catback. There will be alot more released on this in the next month or two .
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Beach Park IL
      How adaptable do you think that IRS might be?
      Donny
      Nov 2016
      Sulphur, La
      I'll be interested in seeing more of it. I've never been a fan of the factory Cobra IRS in a fox. It just does not work well enough for the work and the funny looking wheels you have to run to get them inside the fenders.
      Feb 2013
      Agreed, I hate the way they look when guys put them in foxes. If you look at the silver car we keep posting pictures/videos of is a complete IRS and it tucks the tires properly. We've had custom length fox axles built (and many more parts to make it fit the way it should). It's amazing to drive.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Feb 2013
      As far as putting it on other cars, that's a negative. This one is very specific to the fox. We're using this one to gauge what other ones we might build. But even an SN95 car will have to have it's own kit built.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Beach Park IL
      More IRS pictures please. What is the hub to hub width?
      Donny
      Nov 2016
      Sulphur, La
      If Josh doesn't want to post the pics yet I have a couple on my phone I can text you.
      Nov 2016
      Sulphur, La
      I have a super clean notch that I have had sitting in my air conditioned shop for 25 years. I had the foresight to buy a bunch of NOS parts for it back when they were avaliable. I think I am too far down my straight axle path to do this IRS but I am considering the SLA. I would love to have a 275 up front with a good turning radius.
      Beach Park IL
      This is all could find, I really wanted to see how the front mounted. If I can swap the spindles to their GM style and run Corvette hubs......
      Donny
