      Solid Motor Mounts using Hooley Swap Kit?
      Im running the Holley Swap kit on my 68 Camaro using the urethane mount inserts. Ive decided to mount the turbo fixed to the frame so I need to run solid mounts now. Does anyone know if there is a solid mount that bolts to the frame that is roughly the same dimensions as the urethane setup and not causes height issues with the pan? I would like to keep the brackets that bolt to the block in place but can replace everything if needed.
      TIA
      May 2010
      kitchener,Ontario,Canada
      Just curious and im sure someone else would ask , whats the reason for not mounting the turbo to the engine?
      Ryan Austin
      On Instagram ryanaustinss70
      Its a 85mm turbo so it has some size. On the motor, its just too cluttered with acc drive and radiator w/ dual fans. Mounting it behind the pass headlight off the subframe using a Maven mount.
      Beach Park IL
      These should work and would replace the rubber mounts that are specced in the Holley instructions.
      https://www.umiperformance.com/home/.../#&gid=1&pid=1
      Donny
      Quote Originally Posted by crashz28 View Post
      TIA
      The ICT billet mounts for 4th gen Camaros plug right into the Holley frame stands.
      https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      Beach Park IL
      But this car doesn't have frame stands. 4th gen has the rubber mount on the engine. The Holley setup in a 1st gen has the rubber mount on the frame.
      The UMI part is a direct replacement for the Anchor 2292 mount.
      Donny
