Results 1 to 18 of 18
10-27-2022 #1
LS3 swap Holley EFI vs OEM computer
I just picked up a low mileage LS3 from a 2010 Camaro. Only mods i will be doing to the motor is a bigger cam and all the bolt ons. Trans will be a Magnum T56. I have used the Holley efi systems in the past and they are really great and easy to use. However when I went to go buy the Holley Terminator for a Drive by wire LS3 its almost $4000. Thats more then double what I paid for the Holley system on Gen 1 Ls motors. It looks like Wiringspecialties.com can get me running under $1500. I would still need a dyno tune ($550) but its still cheaper then the Holley. I am looking for opinions on what people think about this. I am also open to other efi systems that may be out there as well.
thanks!1969 Camaro under construction.
1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
10-27-2022 #2
- Oct 2011
- 721
Psi has an engine control kit for $1399, they use an OEM PCM and pedal. You will still need a tune.
https://www.psiconversion.com/produc...its/geniv/T56/
If you want to save yourself money. Buy a standalone harness from PSI it’s $569. You’ll still need a tune obviously and you’ll need to buy a pedal and a PCM from a junkyard or eBay. OEM PCM is like $100 and pedal is $50-60.
https://www.psiconversion.com/produc.../HAR-1037.htmlMy Very Ambitious 69 Build
https://www.pro-touring.com/threads/...lls?highlight=
10-27-2022 #3
