      Sep 2013
      Virginia
      Hi Arthur from Northern Virginia Reston
      Hey everyone
      I have been on here before with my Plymouth satellite but now I have a 1971 Chevelle. This is new to me just picked up a month ago and i am getting used to driving it. It needs headliner and new interior that is it right now and then i will start the upgrading.
      I am looking to start to upgrade and the Chevelle site does not get that much action.
      Here are my stats
      1971 Chevelle Upgrades
      1. 496 Stroker Motor w/4 bolt main block, Balanced and blueprinted
      2. Holley Sniper EFI
      3. Griffin Thermal Aluminum radiator
      4. Gas tank with in-tank fuel pump
      5. MSD Street Fire HEI distributor
      6. Flow master 50 series street mufflers Flow master 2.5'' exhaust
      7. Borg Warner Super T-10 4 speed transmission -2:43 first gear
      8. Transmission cross member powder coated
      9. Hurst Super Street Shifter
      10. Center force dual friction clutch and pressure plate, throw-out bearing
      11. SFl-rated flywheel
      12. Lakewood block plate and scatter shield
      13. High torque starter
      14. optima battery
      15. Auburn Gear Pro Series posi-differential with all new bearings and seals
      16. 12 Bolt rear differential housing with new seals, bushings and powder coated Richmond 3:55 rear gears
      17. UMI Performance rear upper control arms and boxed lower control arms with urethane bushings
      18. All new suspension bushings (front and rear)
      19. New front and rear heavy duty sway bars
      20. New pitman arm, Tie rods, sleeves, center link
      21. New Moog Front and rear coil springs
      22. Rear Suspension airbag leveling
      23. New Cardone Quick Ratio steering gear box
      24. All new brakes, Backing plates , calipers Master cylinders, distribution block
      25. New Body bushings (except 2 below the trunk
      26. New Engine bay wiring and relays.
      Dec 2020
      Hi Arthur. Got a 71 myself. Like the car and color. Yeah feel an older crowd on Chevelle.com and not really into Pro-tourers or Resto-Mods.
      Plans on upgrades or changes?
      Sep 2013
      Virginia
      upgrades
      Here are the upgrades i am planning to do in the next 1-2 years money permitting all while trying to enjoy the car and not having it off the road.
      1. Molded Headliner that is more modern and fits Flat- TMI has it
      2. Radio (current one doesn't work) any suggestions
      3. Wheels and tires .... I am currently looking for some with these specs 18 inch 18x8 front 5 inch back space with 245/35/18-....18 x11 back 6 inch back space and 315/30/18
      4. Vintage Air
      5. Seats currently there is a bench seat but I heard that E46 Convertible BMW seats fit nicely
      6. Jeep LED headlights
      7. 2015 Camaro back seats
      8. Transmission TKX ( current is a super T10)
      side note
      Hey for some reason I can't post on for sale section or other sections other than here. Does anyone know why? the Post thread button show up on those forums. Do i need permissions? Like i stated i am not really new to the site but haven't visited in awhile.
      Hi Arthur,
      Welcome! You should be able to post in any forum except the for sale.
      Sep 2009
      Hey Arthur, Welcome back. Nice looking Chevelle! I just moved to Virginia a few months ago, but we're more central near Charlottesville. I believe you have to have a certain post count before you can post in the for sale section.
      Dec 2020
      Quote Originally Posted by ACworld34 View Post
      4. Vintage Air
      side note
      For head lights look into the Phillips LED 7” rounds
      https://www.usa.philips.com/c-dam/b2...ps-L6024-1.png
      Not too expensive compared to most and look good.
