      Jul 2019
      Ohio
      Trunk Battery Breaker
      I'm working on my trunk mounted battery starting/charging circuit plan and thinking I would like to just run a single 1/0 wire from the battery to the starter, and then run 4/0 to the 175amp alternator from the starter through a distribution block. I would like to use a blue sea 187 surface mount 200 amp breaker at the battery in the trunk. Think that would start and run the car without tripping?
      Jul 2018
      I'm running mine off a 200 amp glass block style post mount fuse cranking a 10.2:1 Big Block
      20220327_090518 by F G, on Flickr
      Jul 2019
      Ohio
      Thanks, so you have the power to the body and the starter both on that 200amp fuse? Sounds like it should work then.
      Feb 2019
      Kankakee IL
      That's what I'm running, bit larger cable though.
      Tracey
