    Results 1 to 16 of 16
    Thread: Catch can.
      Mar 2022
      Tomball Tx
      Catch can.
      know this Topic has been beat to death but I need a little help. Since I put some new valve covers on my truck I'm getting a little bit of oil coming out of my intake and puddling up underneath my fuel injected throttle body.
      So I am assuming my pressure is a little off with the valve cover change.. On the passenger side I have A PCV hooked to the back of my Holley sniper Throtle body itself and that's the only ventilation it's getting. My driver's side has a filter style oil cap. The Valve covers do have baffles on each hole.
      Would I benefit from a catch can? If so how would it be hooked up since I only have I source of ventilation?
      Feb 2013
      El Dorado Hills, CA
      I have a catch can on my LS3 but that's because I read where LS engines are notorious for pulling oil into the intake on the PCV side. It sounds like you have plenty of breathing ability on your engine the way it is. I get very little oil into my catch can but I do get it. If you have oil on the inside of your intake (under your throttle body), I would first check to see if you need a baffle or plate on the inside of the new valve cover where the PCV line is connected. If nothing you try eliminates the pulling of oily vapors into your intake than a catch can should certainly eliminate it.
      Mar 2022
      Tomball Tx
      I checked. The Valve cover does have a baffle where the PCV goes and it has one where the oil cap goes also.
      It looks like you have a throttle body EFI system on there. If that is the case, you want to use a fixed orifice PCV valve.
      Is this a speed density system? No MAF? If so, then an ordinary catch between the PCV valve and the TB should help a lot.
      I'm a bit skeptical about the breather on the left side of the engine. That really should be providing filtered air, or you could add a port to the inside of your air filter base and connect that to the left side valve cover. Using a connection like that will also keep that breather from dripping oil on to the valve cover.
      ​John Parsons
      Mar 2022
      Tomball Tx
      This could be a stupid question, but what is the difference in a fixed PCV and the one that I have now?
      Mar 2022
      Tomball Tx
      It's a holley sniper so no Maf. So you think the filter/oil cap is doing more harm than good?
      How would the catch can be plumed into the PCV ?
      Thanks for yalls responses.
      Newbury Park, CA
      The best air/oil separator on planet Earth: https://www.amazon.com/Mann-Hummel-6.../dp/B01F2NZ6RQ
      It's plumbed: PCV --> Pro Vent 200 --> throttle body vacuum source. The check valve automatic drain means checking the filter element every 12mo just to make sure it's still there.
      I just removed the heads on the Camaro after seven years and a metric s-ton of road miles, thousands of track miles, supercharged, etc. The back of the intake valves look like this:
      Quote Originally Posted by Tim
      I wasn't saying that. The function of that breather in a PCV system is to provide fresh, clean air into the crankcase to replace the dirty air removed via the PCV and engine vacuum. So a good air filter is needed, not just some stainless steel wool. The best air filter in the engine area is the one on top of your throttle body, so that's the best practice.
      ​John Parsons
      Mar 2022
      Tomball Tx
      Again forgive me if this is a dumb question. So the PCV get connected to the inlet (top port) and the outlet gets connected to the the Vacuum on the TB?
      Tim
      Newbury Park, CA
      Yep.
      Mar 2022
      Tomball Tx
      Yep.
      I see Amazon has 4 of those in stock again. When I checked they were out. Those things sell fast. Since they were out I just got a Moroso one. Let's see how it works.. I have the PCV hooked to the side closest to the engine and the TB vacuum hooked to the side closest to the fender. This oil / separator was mentioned for a new truck but it mounted perfectly
      Oct 2006
      Phoenix, AZ
      Hey Carl, What did you use for hose and fittings to connect the Provent? Inquiring minds and all…
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Jul 2019
      Ohio
      I see there are several sizes of the Pro Vent and they recommend sizes based on HP. The 200 is up to 250KW which is 335 HP, then there's a 400 and an 800 which are getting really big in physical size. What are your thoughts sizing vs HP. Would the using the 200 for a fairly stock GenV LT5 be sufficient?
      Sep 2017
      Catch can
      Here my catch can. A nuke performance competition can very nice unit. 316.00 plus a 27.00 drain and of course hoses.Name:  IMG_20220504_204711.jpg
Size:  313.8 KBName:  IMG_20220504_204704.jpg
Size:  336.3 KBName:  IMG_20220504_204653.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Sep 2017
      I recently added a second so I got one for the valley and one for the valve covers
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
