    Results 1 to 11 of 11
    Thread: Sniper Tuning
      Elk Grove, CA
      Sniper Tuning
      I have a Holley Sniper on my relatively stock SBC and sometimes when I step on the pedal it backfires(or something like that), any clue to what that is?
      Aug 2012
      Peoria, AZ
      Are you using the Sniper to control your ignition timing?
      Lance
      Elk Grove, CA
      I’m using the large cap HEI distributer, i remember setting the timing when I installed it, I went just the basic setup. I’ve been thing of buying the Hyper Spark if that would help
      Feb 2019
      Kankakee IL
      Sounds like a timing issue. Any chance you're off a tooth on the cam?
      Tracey
      Beach Park IL
      Backfires? Like out the exhaust?
      Or does it sneeze through the throttle body?
      What happens to AFR when you step on the gas and this happens?
      Donny
      Elk Grove, CA
      Sneeze and I think the AFR drops a bit. It almost or sometimes dies so I keep my foot on the throttle to keep it from dying. I disconnected the battery and reinstalled the set up and took it for a test drive and it sneezed
      Elk Grove, CA
      Highly doubtful my timing chain would be off tooth, motor is low mile, I’m thinking it’s timing on the distributer
      Feb 2019
      Kankakee IL
      Quote Originally Posted by elwaupo View Post
      I accidentally installed the distributor 180* off in my 351W. It started but ran like s**t doing some things similar to what you describe. I realized my mistake and spun it around and it was golden.
      Tracey
      Elk Grove, CA
      Mine is non timing controlled
      Send me an email with your current global config file.
      projectgattago at gmail dot com
      Elk Grove, CA
      I’m out of town this weekend but I will next weekend, thx
