      Sep 2012
      Country Flag: Ireland
      Help with 502 timing specs
      Hi guys,
      I just picked up my new '47 Buick Super streetrod and it has a crate 502 chevy engine. All I got with the car was 4 pages detailing the customisations made to the car, but no details on the engine other than its a "crate 502".
Size:  953.2 KBName:  F05C4099-3058-4752-97F0-97366B98D654.jpg
      I've pulled the numbers off the block (14096859) and the casting date (C313) and from what I can tell its a 502 GEN V - but I need help confirming that.
      Also, where can I go to get the stock timing specs? The Chevy site seems to just list the details for the current engines.
      Nov 2013
      I see you have an HEI. You need to know what part number it is, and what amount of centrifugal advance it has been set up for. The 502 is a mild engine. You will want to have around 14 degrees timing at idle, and 36-38 at full advance by 2800 rpm. Then connect the vacuum advance to full manifold vacuum so that you have 26-28 advance at idle.
      I would also strongly advise to get rid of that power robbing and poor cooling flex fan, install a thermostatic clutch fan, and a proper shroud for it, which the blades sit half into and half out of the shroud.
      Quote Originally Posted by hipockets View Post
      ^^^Sound advice.
