    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 69
    1. #21
      Jun 2018
      Alamo, CA USA
      I wouldn't use aluminum with any fuel that contains ethanol. I like NiCopp because it is easy to bend and flare and is non-corrosive. I also like how looks.
      I've used all those materials. All will work fine.
      • I prefer nicopp: it's easy to work, and bends and flares easily. It comes in rolls, so you have to work a bit to make the straight sections "straight". Still, I don't use anything else anymore.
      • Aluminum comes in several alloys and stiffness, from the completely annealed rolls you get from Summit/Jegs to the very stiff sticks you can get from McMaster-Carr. I've had success with all of them, and prefer to start with the straight versions.
      • Steel rusts, so you need to paint it or coat it after it's been bent to shape.
      • Stainless looks nice but is a real bitch to flare, and often cracks at the flares when used for brake lines. It tends to seep through flares in general too.
      Very nice comparison here. Thank you.
      With hard tubing, do you have to considering linings or is that not a thing with hard tubing? Is it all just bare material?
      1973 Camaro: LS427/570, T56, Speedtech ExtReme subframe/torque arm
    2. #22
      It's just bare metal.
    3. #23
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by slimjim View Post
      Has anyone considered running the PTFE line for hotrodfuelhose? looks like an easy option
      I have, found it to be nearly identical to the Holley stuff. Sometimes they have some good discount codes that make it worth it.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
    4. #24
      Aug 2005
      Hamilton, NJ
      With aluminum, or even ni-comp, do you guys use rockguard or such to protect it?
      Scott from NJ.
      Vent Windows Forever! ...
    5. #25
      Quote Originally Posted by BonzoHansen View Post
      I don't, but it's probably not a bad idea.
    6. #26
      Mountain Springs, Texas
      I have used rock guard in the same locations as the factory.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    7. #27
      Jun 2018
      Alamo, CA USA
      Picked up 20' of nicopp from Amazon. Cheap. Smaller than I'll eventually use, so easier to bend. Was less than $20. Did so just to practice and start seeing if I could build a template for around the car. Could use some help on tools. I'm ok spending money on good tools if I'm going to get use out of them forever. What tube benders and flaring tools are you guys using?
    8. #28
      Quote Originally Posted by roguegeek View Post
      I just got an Earl's flaring tool. I believe the same kind is sold by various companies. Mine has dies for both 37 degree AN single flares and 45 degree SAE double flares. Pretty excited about using it.
    9. #29
      Oct 2011
      This is what I got. Different companies make this type of tool but they all look the same and perform the same. Like I said before. It was my first time making brake lines and fuel lines and I have zero leaks. The way this tool is designed there’s no if’s ands or buts about the flares, you flare it once and it’s perfect every time. The other cheap tools you can crank on the handle maybe a little more or maybe you didn’t crank it enough etc. also this one has the dyes for 45 double fare and 37 single and bubble. It’s the only flare tool you’ll ever need.
      https://www.amazon.com/-/es/Professi...%20tool&sr=8-4
      For tubing benders I used this. The nicopp is very easy to bend and most bends you’ll actually be making by hand because they will be soft bends. But in case you need a tight radius 90 or 180 you’ll definitely need the tool.
      https://www.amazon.com/LORESO-Bender...tubing+&sr=8-6
      For rock guards I just put it on all the brake lines and fuel lines. It’s cheap and can’t hurt right? I got the stainless versions. Here’s links
      https://www.amazon.com/Stainless-Bra...5644297&sr=8-3
      https://www.amazon.com/Stainless-Bra...5644379&sr=8-3
      Here’s the clamps I bought for brake lines and fuel lines. If your going to use the rock guard then upsize the clamps from 3/16 to 1/4 and from 3/8 to 1/2.
      https://www.amazon.com/LOKMAN-Stainl...8-6&th=1&psc=1
      I try to get EVERYTHING from Amazon that way if I don’t like it or doesn’t fit or doesn’t function or feel/looks poor quality I can return it no questions asked for free!
    10. #30
      Aug 2015
      charlotte
      Quote Originally Posted by joeko23 View Post
      I try to do the same as much as possible. I wish they stocked more
    11. #31
      I have also used the Rigid 377 37 degree flaring tool and it works great.
    12. #32
      Sep 2016
      Bakersfield, CA
      Ditto, I have the Ridgid tool for both 45 and 37 degree.
    13. #33
      Jun 2018
      Alamo, CA USA
      That certainly looks like a nice tool, but man, that price. Buy once, cry once, right?
      - - - Updated - - -
      These are all super helpful. Yeah, I definitely like to try to get what I can from Amazon. The flaring tool's price is a lot easier on the wallet over the Earl's.
      - - - Updated - - -
      Looks like a nice tool that will do the job. Price is good too. I'm weighing this vs the TGR listed above. The TGR could be overkill since I don't think I'll be using 45 degree flares anywhere, although I could be wrong about that.
    14. #34
      Jun 2018
      Alamo, CA USA
      Any more suggestions out there for benders and tube cutters? I got a recommendation for the Imperial Tools tube benders. I'll probably grab that and the basic Ridgid tube cutter there isn't something drastically better I should be grabbing.
    15. #35
      All of your brakes will be 45 SAE double flares.
    16. #36
      Jun 2018
      Alamo, CA USA
      Ok, well that makes the value of those tools immediate go up for me. Thank you for pointing this out.
    17. #37
      Jun 2018
      Alamo, CA USA
      Ordered the TGR Flaring Tool, Imperial Tool Tube Bender, and Ridgid Tube Cutter. Thanks for help on this.
    18. #38
      Oct 2011
      You’ll love the TGR flare tool. Like I said your flares will be 100% and leak free! If you don’t like it return it after you use it. LOL
    19. #39
      Jun 2018
      Alamo, CA USA
      Gonna ask an off-topic question here just to see if I can save myself (and all of you) from yet another post of mine. I'm playing with the routing of the fuel lines right now. Obviously, there's places where I must use fitments, but is it good practice to try and make single longer hard tube going from back to front or is it actually good to use some fitments here and there? Maybe where there's tighter turns that the bending tool can't make? I guess I'm looking for overall good practices to use when mocking up these lines.
    20. #40
      Jul 2017
      Island Lake, IL
      There's a lot of conflicting information on this if you poke your head around with Ethanol. Some people say it's the worst corrosive thing ever and others swear by it with no claimed issues at all.
      For those who may be worried about ethanol, brands like Lucas and Sta-Bil offer fuel treatment/conditioner and stabilizers for storage.
