      Oct 2007
      Mystery blinker issue
      67 Camaro with 69 valance and LED park/marker billett lights
      Idid it column with converter connector to go form horeshoe style to flat..
      factory headlight switch.
      all new painless fuze box and harness.
      Electronic flasher with ground.
      1157 tail light bulbs.
      Problem
      when i use the blinker both FRONT lights blink on Left or on right.
      When I use the blinker both REAR lights work perfectly when using Left Left blinks and Right/Right
      When i use the park lights just park lights come on.
      When I use park lights and blinker Both FRONT linght blink.
      Wiring.. 3 wires out. light blue/dark blue and purple..
      purple goes form one light to the other.. Blues go to other wire one on Left one on right.
      Ground is through mounting of housing assembly, tried additional ground.. did not help.
      assume some kind of feedback issue but I am at the end of my rope on where to look..
      Help wellcome.
      67 Camaro In progress
      Nov 2011
      Wylie, Texas
      It sounds like your light blue and dark blue wires are wrongly connected together. Did you try doing a continuity test between these two wires with the front bulbs removed and then again with them inserted? Are the front bulbs oriented correctly, sometimes they can be inserted such that the LED bulb contacts are reversed.
      Oct 2007
      Quote Originally Posted by blitzer454 View Post
      I can't remove the bulb since they don't have sockets just LED board.. I can ck for continuity disconnected.. just for sanity purposes..
      Beach Park IL
      Check the ground on your dash indicators.
      Check the connections on your dash indicators, where the D/BL and L/BL wires split off particularily.
      Donny
