    Results 1 to 16 of 16
      Jun 2018
      Alamo, CA USA
      Bell housing alignment analysis...
      I'm aligning a Quick Time RM-8019 bell housing onto an LS427 and I'm doing so with the help of the QuickTime RM-130 indexing plate. I'm using the process as defined in the instructions as well as the Holly instructional video. Found the most positive point which was around the 5-o-clock position and have done several sweeps. All numbers are coming back consistently. Here's an image of my readings...
      Click image for larger version.
      I would like confirmation that I'm analyzing this properly. So what I'm seeing here is I have an offset of -0.0095" (0.019/2) and that needs to move the bell housing towards my zero mark (5-o-clock position). Correct?
      Also, does anyone know what dowels I need to get that will move align the bell housing properly? I've read they come in .007, .014, and .021, so I'm guessing I need the .007 offsets. Is this a GM part or should I be getting it from Holly? A part number would be absolutely fantastic.
      Thanks for the help, everyone.
      1973 Camaro: LS427/570, T56, Speedtech ExtReme subframe/torque arm
      Your analysis that you need .007" offset dowel pins is correct. I always thought that LS engines had .500" dowel pins, but I am now questioning that. Since you have an engine easily accessible, take some calipers and get the diameter of the dowel pins. Lakewood has many options, but the first step would be to confirm the pin diameter.
      Jan 2014
      Portsmouth NH
      Hi Rogue,
      The way I see it, you will need to have the offset of the pin towards the -0.019". Ultimately you would want 0.009" but the 0.007" should get you within the Tremec 0.005" max run out spec. Do make sure and check it after you do it.
      https://www.tremec.com/anexos/TREMEC...ation.Tips.pdf
      Cheers, Steve
      Jun 2018
      Alamo, CA USA
      Here ya go.
      - - - Updated - - -
      Quote Originally Posted by Motobrewmaster View Post
      Excellent. Thank you, Steve.
      Quote Originally Posted by roguegeek View Post
      Here ya go.
      - - - Updated - - -
      Lakewood lists some .007" offset dowels in that diameter. I believe it's the same as a regular small block.
      Jan 2014
      Portsmouth NH
      I was able to get mine very close. BLACK are the first readings. PINK are after offset pins. Well within the 0.005" max limit.
      Jun 2018
      Alamo, CA USA
      Assuming I have the diameter right, I (think) found two options for offset dowels. There's the Lakewood offsets and the RobbMc offsets. Anyone have any thoughts on any of these? Also, forgive me if this is a stupid question, but what's the need for the screw in the dowel? Aren't they just friction fit?
      Jun 2018
      Alamo, CA USA
      Yup. That came out nice.
      Jan 2014
      Portsmouth NH
      The set screw is to prevent the pin from walking (turning) due to vibration.
      Apr 2010
      Jersey Shore
      The RobbMc ones are all that I use now... the set screw expands the slightly undersized dowel to lock it into place. It makes fine tuning the rotational position FAR easier than pounding in the lakewood ones and then trying to rotate them after they are in. Worth the few extra $$
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by vette427-sbc View Post
      Ordered them last night. Now the wait begins. I wonder how quickly they turn around orders.
      NJ
      Feb 2016
      Texas
      Did you check/verify the parallel alignment between the block and the BH first before checking the runout?
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by TBART70 View Post
      I linked to that video in my post.
      - - - Updated - - -
      Quote Originally Posted by ctcz28 View Post
      Yes. I was all good there.
      Jun 2018
      Alamo, CA USA
      Did we do the math wrong here? I got the .007 pins as recommended and installed them. I'm now reading an offset of -.006, which makes sense, since...
      -.019+.007=-.012/2= -.006
      So the offset dowel pins did exactly as expected. The problem is -.006 is still out of spec. Sounds like I was suppose to get the .014 offsets which would have given me an offset of -.0025, well within spec, since...
      -.019+.014=-.05/2= -.0025
      So did I get the wrong pins?
      Edit: Ok, no. That math above that I did was wrong. Using .007 offset dowel pins should have put me at an offset of .0025 (-.019/2=-.0095+.007=-.0025), well within spec. The problem is my offset dowels didn't move the full amount. That's absolutely strange. I tripled checked those number. I even removed and the bell housing several times, re-torqued everything, repositioned the dial, and re-ran tests. I ALWAYS came out to -.019 or -.0195. Always. Guess I need to troubleshoot this more.
      Jul 2011
      Colorado high country
      How did this turn out for you?
