    Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 ... LastLast
    Results 81 to 100 of 245
    1. #81
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by ponchoblue View Post
      what wheels are those backspacing and tire size
      The wheels are a reproduction of the 2011 vette wheels 18" x 10.5" with 7 7/8" BS i have 275- 40 on the wheels right now but my plan is to run 295 on all 4 corners
      I test fitted a 315 in the rear, Should i want to get another pair to run bigger in the rear.
      David Sloan
    2. #82
      Aug 2002
      Waleska Ga.
      My mini tub was more for the caliper clearance than for a bigger tire ,So I will have 14”s of room for bigger tires if I want!Name:  F3C3FB1D-258E-40D1-8077-05C4EE185EBC.jpg
      David Sloan
    3. #83
      Woodstock, Ga
      Looks good man, lots of progress since the last time I came by!
      I'll have to find some time to get by and help or hang out.
      Robert
    4. #84
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by RS_Customs View Post
      Robert
      Thank you sir!
      I am finishing up the wheel tubs right now, welding is done just got to do the clean up now.
      You are always welcome at my house.
      It would be fun to work on stuff together again!
      David Sloan
    5. #85
      Aug 2002
      Waleska Ga.
      Wheel tubs are welded in, I got started cleaning up the welded on the tubs! Name:  26C10166-660A-488F-9BFB-F72C43280961.jpg
Size:  393.7 KBName:  887B5D2E-C888-4151-8777-548C0C8AD45D.jpg
      David Sloan
    6. #86
      Aug 2002
      Waleska Ga.
      Figuring out the smugglers box new floor. Needs to be ventilated so this is my idea so far.Name:  CD7E8503-6DEB-4CD6-B1CE-C5BF52D0FD74.jpg
Size:  465.0 KBName:  F814AA77-71B7-4954-90DF-C7A9049F1518.jpg
      David Sloan
    7. #87
      Nov 2010
      Real nice shop/garage....
    8. #88
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by Tincup View Post
      Thank you sir!
      This is my happy place. lol!
      David Sloan
    9. #89
      Aug 2002
      Waleska Ga.
      More work on making new panels and adding to frame and body to make it more ridged.Name:  5DED7377-494A-4C37-91B0-D470E1799DE9.jpg
Size:  440.0 KBName:  4B0EBC98-32AD-4CD6-98A0-E5BE207A7DA1.jpg
      David Sloan
    10. #90
      Aug 2002
      Waleska Ga.
      Back on the smugglers box floor.Name:  B242168E-7B96-4149-9946-5DD6AFBE0CD1.jpg
Size:  427.4 KBName:  2CE7B4F4-CDE6-4AAF-B19B-A5A5636AA639.jpg
Size:  470.6 KBName:  28E6AA30-9324-4754-B7AF-13CB303051C6.jpg
Size:  502.8 KBName:  7152C1AC-C946-41E8-957B-3BFBE58DCF74.jpg
      David Sloan
    11. #91
      Aug 2002
      Waleska Ga.
      Got both lower sides mocked up!Name:  D945C24C-7CC7-4C9E-AD2B-C26E577265B5.jpg
      David Sloan
    12. #92
      Looking good David!
    13. #93
      Aug 2002
      Waleska Ga.
      Looking good David!
      Thank you sir!
      I’m sure it’s not for everybody, it’s out of my normal as far as fixing the body of these older cars. Lol!
      David Sloan
    14. #94
      Aug 2002
      Waleska Ga.
      Motor and transmission mocked up, time for the exhaust to turbo tubing!Name:  03A9E988-3783-4638-82C1-361636490BFC.jpg
Size:  518.6 KBName:  EB46496E-D650-4A47-A810-AAD8ACCCB262.jpg
Size:  451.7 KBName:  2D7B92CF-5F42-4424-BD5B-85346B330C68.jpg
Size:  462.2 KBName:  27258615-E6FD-4E94-A485-96DC5CD59B4E.jpg
      David Sloan
    15. #95
      Aug 2002
      Waleska Ga.
      Hot side mocked up!Name:  63015A19-CC80-40D4-BDEB-AAFDDFFA313B.jpg
Size:  445.1 KBName:  FFD07A31-01CE-433E-B3AC-140DA4B7F414.jpg
      David Sloan
    16. #96
      Nov 2018
      I was wondering what you were up to back there. That's exactly how I plan to turbo my truck, if I decide it needs more than the engine. I'm already moving some stuff from under the hood to behind the cab, and will be using the front of a bed welded a couple of feet back from the actual front of the bed to make a box for it, and will use an aluminum tool box lid to make it look like there's just a tool box back there. The rest of the bed will be sealed and lined, covered with a hard bed cover and used as a trunk instead of a bed.
    17. #97
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by Vimes;[URL="tel:1353306"
      1353306[/URL]]I was wondering what you were up to back there. That's exactly how I plan to turbo my truck, if I decide it needs more than the engine. I'm already moving some stuff from under the hood to behind the cab, and will be using the front of a bed welded a couple of feet back from the actual front of the bed to make a box for it, and will use an aluminum tool box lid to make it look like there's just a tool box back there. The rest of the bed will be sealed and lined, covered with a hard bed cover and used as a trunk instead of a bed.
      cool idea on the tool box !
      I'm planning to build a wall between the smugglers box area and the rest of the bed. I’m also going to build a cover for the bed.
      David Sloan
    18. #98
      Aug 2002
      Waleska Ga.
      So I went to the garage this morning to figure out the turbo flange mount and didn’t like the fact that the turbo was close to the center of the area it is occupying!
      Decided to move it closer to the wall by 2” .
      Should give me more room for cold side and exhaust.Name:  4092F9FD-120B-481A-ACC1-485A09A0E796.jpg
Size:  390.8 KBName:  F6C7630E-7037-4F94-A2EE-128BA143B8F1.jpg
Size:  348.3 KBName:  C2F9904A-F5AA-4C0C-8BD7-149F299FAC2B.jpg
Size:  346.8 KBName:  6412FA5A-7AC2-4202-9EE4-D62BC7577845.jpg
Size:  447.9 KBName:  90013A5F-04E8-4A7A-98BF-437152B3A0F2.jpg
      David Sloan
    19. #99
      Aug 2002
      Waleska Ga.
      Moving towards making the exhaust from the turbo. I plan on a traditional duel exhaust out the rear.
      I have some old bullets mufflers from a car that was parted out they should be perfect for the turbo
Size:  556.3 KBName:  CE5C4B0E-5DDA-41BB-A86F-17FE50F1FA40.jpg
Size:  631.8 KBName:  91C11D3D-06BE-4321-85B4-0D09D4CA3568.jpg
      David Sloan
    20. #100
      The Netherlands
      Country Flag: Netherlands
      Ah, nice... found your build thread, I was missing the updates since you left FB. You've made some good progress! Do you plan on some heat insulation between the turbo bracket and the cab?
      Keep up the good work David! :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
