    Results 1 to 15 of 15
      May 2016
      Bay Area
      Drive By Wire Pedal Assembly
      I'm running a drive by wire setup on my 69 Camaro, LS7 with Nick Williams 102mm TB, Holley Terminator X Mac ECU and a T56 transmission. Is there a DBW pedal assembly you guys like to run? Thank you
      May 2016
      Bay Area
      In researching I came across the Lokar control harness and pedals. Does anyone know if these will work with the Terminator X Max? Lokar is claiming less pedal lag over OEM.
      https://www.summitracing.com/parts/lok-bdbw-gm06
      https://www.summitracing.com/parts/lok-xdbw-6012
      Jun 2010
      Deployed
      I run an OE pedal...I have no complaints about pedal lag. Have you gone through the instructions for the T-Max? What does it recommend? The most important thing is your ECM is compatible with which pedal you choose.
      1970 Camaro/DSE build
      May 2016
      Bay Area
      @badazz81z28 The Lokar pedal looks to be newer to the market so I'm trying to figure how/why they claim "The sensor is programmed on the pedal to optimize electrical output for quicker throttle response, producing no pedal lag and three times the performance of OEM pedals"
      3x the performance of a pedal seems like a silly statement to me. T-Max recommends the OEM pedal but again maybe the Lokar stuff isn't on Holley's radar yet.
      Jun 2010
      Deployed
      Quote Originally Posted by no_go nico View Post
      Have you driven a DBW vehicle? Maybe a new corvette or Camaro? Do you feel there is an issue with the stock pedal response? I think it’s all marketing BS...so the pedal responds .0005 sec versus .0007 sec...
      I don’t think it’s really even the pedal...it’s more to do with how fast the computer can interpret the input to give an output. I would save your money. Their pedal looks more application specific for a hot rod who wants to use a “hot rod” looking pedal versus the modern one.
      May 2016
      Bay Area
      I think you're probably right. It's less about the pedal and more about the control module. FWIW, Lokar part #XBDBW-HOLLEY01 will work with the TERM X/X MAX and Dominator ECU paired with XDBW-6012 for a pedal for the folks looking for more of a hot rod pedal assembly.
      I just looked at those prices...wow...
      For a 69 Camaro there are several companies making mounts to use the CTSV pedal, which is what Holley recommends. Way less expensive and with the money you save, you can hire me to do the tuning :-)
      Martinez, CA
      I used the stock FBY pedal in my car. It works fine. I made a simple bracket to change the angle of the floor slightly so at full pedal I’m on the floor. Simple plug and play.
      Worlds Fastest LFX powered 1966 Chevelle, with a 3.6L/217 CI, 4 cam direct injected V6, 6 speed auto, full Hotchkis suspension, 4 wheel Wilwood discs, white w/red interior, cowl hood. 3260 lbs w/full tank.
      May 2016
      Bay Area
      not the cheapest stuff but i'll let you know how they perform
      Jun 2016
      Upstate NY
      I run a Holley Dominator, NW 102 and a factory pedal with the scarebird adapter. Make sure you select the correct TB in the drop downs that should be on the car (i.e., ZL1, CTSV, etc.) If the wrong part number is used, it will be delayed. You're also going to have to play with the pedal settings to get it to idle, as the blade needs to be closed more than the stock one. Took me a while to realize that after I had a high idle.
      May 2016
      Bay Area
      Thanks for the tips. Im using also running the NW102, which TB does Holley consider that in dropdown?
      Quote Originally Posted by ORBandit View Post
      Jun 2016
      Upstate NY
      I just pulled it from Rockauto GM GENUINE 2173151 {#12601387, 12629992}. I don't remember specifically which part number Holley listed (don't have my laptop with me)
      Holley only lists one approved pedal, which is the first gen CTSV pedal, same one that GM sends with their kits. However, I k ow from experience that the Impala SS pedal also works flawlessly. Other pedals may work as well, I've just not tested them first hand.
      May 2016
      Bay Area
      I was referring to the TB. I have never use the Holley software so forgive my ignorance. If the Nick Williams throttle body is not listed in the drop down which selection are you supposed to make?
      I'd probably try the LS 3 TB first.
