    Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 61 to 80 of 186
      Apr 2019
      Louisville, Kentucky
      Same question, what did you use to make the bed floor? I raised my bed floor 4” and also used stainless for the filler area below the tailgate. You do have an awesome build!
      Nice! Then use a slide hammer?
      Mountain Springs, Texas
      I would be concerned about moisture collecting between washer and body panel. I make an exact size plug and attach a stud to it with a stud welder. Or just use one of these as a backer and weld it up.
      https://www.ebay.com/itm/15301073625...Bk9SR8jok-HnYA
      Sorry if I misunderstood your method.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2017
      Oregon
      Don
      I thought about that and see your point. I didn't see how this would act any different then the multiple overlapping seems with spot welds on the pickup, besides my cars never see the rain Anyone who has worked on C10's knows what factory rust buckets they are.
      Oct 2017
      Oregon
      Closing in on Fabrication Complete
      Most of the "dirty work" is done. Cleaning up under tunnel.
Size:  361.6 KBName:  20230102_134154.jpg
Size:  378.2 KBName:  20230102_153415.jpg
      Oct 2017
      Oregon
      Assembly Progress
      Sure nice putting together stuff that fits. Name:  20230124_115613.jpg
Size:  680.5 KBName:  20230127_105339.jpg
Size:  648.9 KBName:  20230127_144849.jpg
Size:  663.5 KBName:  20230127_144859.jpg
Size:  704.7 KBName:  20230127_151418.jpg
      Oct 2017
      Oregon
      Progress
      Getting the Cab ready for primer. Name:  20221221_145147.jpg
Size:  384.3 KBName:  20221221_145127.jpg
Size:  366.1 KBName:  20221214_083741.jpg
Size:  313.4 KBName:  20221216_134313.jpg
      Oct 2017
      Oregon
      Powder Coated BK08
      Oregon Powder Coating did a great job.
Size:  680.5 KBName:  20230124_083443.jpg
      Oct 2017
      Oregon
      Un boxing clutch stuff
      These things have been sitting on my shelf for a long time.
Size:  595.1 KBName:  20230216_115406.jpg
      Oct 2017
      Oregon
      Cab is Green
      Sprayed out beautifully. Name:  IMG20230810144716.jpg
Size:  124.3 KBName:  IMG20230811194029.jpg
Size:  129.6 KBName:  IMG20230811194043.jpg
      May 2017
      The Stance will be Absolutely Sick!
      That's a beautiful exhaust system!
      Is the plan to have gauges in the stock location as well as the dash?
      Oct 2017
      Oregon
      The 12.3 can display all gauges but I will run a 4.5" Speedo and Tach on the Munsey Speed blank dash bezel.
      Quote Originally Posted by jschmidt97306 View Post
      I plan to do the same, but using the smaller dash for the auxiliary gauges.
      Oct 2017
      Oregon
      Late Christmas
      Got my radiator and drive line this week. Name:  20230113_093846.jpg
Size:  586.4 KBName:  20230114_082755.jpg
Size:  435.8 KBName:  20230114_082857.jpg
Size:  455.2 KBName:  20230114_082908.jpg
      Sep 2017
      I'm in love with this build already. My dad had this truck in this very color when I was around 13.
      I'll wat it close.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Oct 2008
      Toronto, Canada
      Great build! I'm a big fan of that stainless tig exhaust welding...........love it. I don't know whether this will matter but I thought that when welding the o2 bung it has to be welded at the mid point(3:00 or 9:00) of the pipe or higher so that the condensation doesn't accumulate when cooling down and damage the sensor, I could be wrong. Anyways keep posting.
      - - - Updated - - -
      Ha! more eye candy, nice work.
      Oct 2017
      Oregon
      O2 Sensor
      Good Point, I will check it out. The headers are from Ultimate.
      Feb 2013
      South Carolina
      Engineering documents for mounting O2 sensors are a minimum of 15 degrees from horizontal and 45 degrees being preferred (I used to work for Bosch designing O2 sensors).
      It keeps water from pooling around the sensor element, which can cause cracking at startup when the heater first comes on.
      I won't say it hasn't been done differently, just putting the original intent out there.
