    Results 1 to 11 of 11
      Jun 2018
      Alamo, CA USA
      Bell housing recommendations...
      '73 Camaro, LS427/570, T56. Plan is track days and daily driving. My priority is safety and reliability over cost. I'm getting a few recommendations on bell housings that I've been told to research.
      I'm sure there's more out there I should be considering. These are just the ones I've been told to check out so far. Would love to hear your opinions and recommendations.
      1973 Camaro: LS427/570, T56, Speedtech ExtReme subframe/torque arm
      May 2018
      way east on a rock
      QT is the only one with a SFI sticker/certification on it. It's installed on the majority of builds you'll see here.
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by shelteredchevelle View Post
      Is there any other housing I should be considering that's SFI-approved?
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by roguegeek View Post
      Although it's not SFI certified, you may want to check out the Quicktime RM-8019(we call it the 8020LP). It's just like the 8020 but has the bottom "lip" removed so it doesn't hang lower than the oil pan.
      https://shop.bowlertransmissions.com...vy-low-profile
      visit us on the web at www.bowlertransmissions.com
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by Craig@Bowler View Post
      I was looking at that one. Do you have any idea why it isn't certified? Seems like the exact same thing as 8020, but without the lip.
      May 2010
      kitchener,Ontario,Canada
      i have a ls/t56 quick time bellhousing id sell ....only one problem is i removed the sfi sticker when i went to paint and detail the transmission , just never ended up doing the bellhousing . it was only used for mock up otherwise its new
      Ryan Austin
      On Instagram ryanaustinss70
      Jun 2018
      Alamo, CA USA
      What did you replace it with and why?
      Because removing the lip negates the SFI certification standards.
      The SFI bell housing rules made a lot of sense in the 60s when racers would routinely rev engines to 9-10K RPM while using cast iron flywheels and side stepping the clutch. Do flywheels break? Of course. Is it a huge concern? Not in my opinion. I understand the need to be safe, but if we are that concerned about safety, we wouldn't be building 50 year old cars, but should be driving Volvos.
      May 2010
      replaced it with nothing and ummmm because lmao , i wanted to free up some cash so i sold my t56 mag. since then I've been thinking of a 10 speed auto. so to be honest and answer you . replaced for no real reason and with an auto ...??? make me a good offer ill send it your way . only reason i haven't posted it for sale is because knowing my luck ( god hates me ) ill have 14 guys want it but then when i tell them it doesn't have the sfi sticker they wont want it lol
      Ryan Austin
      Feb 2016
      Lawrenceville, IL
      They won't certify it since it isn't fully bolted along the bottom edge. It's built to the exact same standards as the regular RM-8020 so I wouldn't be worried about it unless you need the SFI certification, then I would go with the RM-8020.
      Sep 2016
      Bakersfield, CA
      I sure wish they had made this for a Pontiac engine too. Mine has been self clearancing on railroad crossings that are all around my house and I'm about ready to just grind the **** out of it out of frustration to make it flat on the bottom!
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
    Tags for this Thread
