    Results 1 to 9 of 9
      Nov 2020
      Planning an Optima USCA BUild
      Hi guys, I'm new to the pro touring world, but love the attitude of building cars meant to be driven!
      I'm considering building a pro touring car for the optima GT Vintage class, and looking for some rule clarifications surrounding the "TCV" (Tube Chassis Vehicle) rules. I did some searching around but didn't find much, I think this is a relatively new add? Any ideas where I should start reading? The rules are very vague. I get this feeling that they are meant to be able to disqualify cars that they don't feel fit the spirit of their rules, which I get, but the last thing I want is to spend a few years building a car to find out it'd have to run in the Outlaw class.
      This was mainly just to say hey and get pointed in the right direction, but here are the rules I'm referring to if you're not familiar:
      10. Tube chassis vehicles (TCV’s) - TCV’s are not typically within the spirit of the OSUSCseries, however, we acknowledge that they can be built into acceptable performancestreet cars. Tube chassis cars are defined as vehicles with one or more of the following:
      • Firewall, has been moved from original factory position, or removed/replaced toaccommodate chassis installation (this may also include factory floor and trunkpans)
      • Chassis does not use original factory mounting points
      • Roll cage is integral to chassis
      • Body panels are attached directly to chassisAftermarket or factory replacement chassis that use factory mounting points, frontsubframe assemblies and other certain aftermarket components may not be consideredtube chassis.
      All TCV’s must meet all of the following requirements to participate in the OSUSC series:• must have a factory OE VIN# attached to the vehicle and must be licensed andregistered for street driving.
      • must weigh a minimum of 2600 pounds
      • must not exceed 300 pounds of ballast
      • must run in the Outlaw class regardless of overall weight or aero configuration
