    Results 1 to 15 of 15
      Nov 2010
      Ventura County CA
      Clutch master mounting
      I'm looking for alternatives to the bent bracket mounting approach for l the clutch master. I came across the Silversport design and really like it but I'm shocked by the price. It uses a machined adapter to directly mount a Wilwood master to the firewall opening. A plate inside the firewall reinforces the opening and because it mounts over the original opening it should be easy to make weather tight.
      Does anyone else make a similar mounting arrangement?
      Have you looked at Modern Driveline? For the record, I use the Siver State (bought when it was Keisler) setup in my GTO and use the Modern Driveling setup in the Cougar.
      Nov 2010
      Ventura County CA
      For my application (70 Nova) it looks like Modern Driveline uses the bent plate adapter. Thanks for the suggestion though.
      Quote Originally Posted by TheBandit View Post
      How about Bowler?
      Feb 2016
      Lawrenceville, IL
      How about Bowler?
      Thanks for the recommendation Andrew, but ours is very similar to the Modern one as well. We use the plate that DSE builds and we add the rest of the parts needed to complete the kit.
      visit us on the web at www.bowlertransmissions.com
      Quote Originally Posted by Craig@Bowler View Post
      Craig,
      Didn't you guys have a billet mount at some point? Maybe I was thinking about something else....it all blurs after a while...LOL
      Sep 2016
      Bakersfield, CA
      I have the SST one posted by the OP, I like it a lot. I can't imagine any other way of mounting it to be honest and just thought they were all like that.
      The fluid reservoir and mounting plate is cheap crap tho, I went with this and ran a billet reservoir like the RB and EM: https://www.summitracing.com/parts/EMS-MS110-71BA
      I think SST offers the RB w/bracket as an upgrade to that package if you call them.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Nov 2010
      Ventura County CA
      Thanks for the reply Anguilla. What are "RB" and "EM"? Is RB remote bleeder?
      I emailed SST and they will sell me just the master side of their hydraulic arrangement without their slave. The slave looks like it has just a single line coming off with a teed-in bleeder; I am concerned that might be tough to bleed. They quoted $299 for the items circled which I think is very reasonable.
      Name:  sst hydraulics.jpg
      Sep 2016
      Bakersfield, CA
      Ring Brothers and Eddie Motorsports are the ones who make the billet reservoirs I mentioned to work with that Wilwood brake master bracket I linked to.
      Their slave is a piece of cake to bleed with that single line.
      Nov 2010
      Ventura County CA
      Thanks for the feedback, that's good to hear. What method did you use to bleed it? Are you running more stuff from SST? They provided a very comprehensive quote for me. Some items seem to have a high premium, but I like how thorough they are and it might be worth a premium for everything to be pieced together already.
      I prefer a translucent reservoir so I can easily check fluid level.
      Sep 2016
      Bakersfield, CA
      I bleed it just like you would brakes, with someone in the car pushing the clutch pedal following my commands. Upon initial installation, gravity bleed it and you're good to go to start regular bleeding.
      I bought my entire Magnum kit from SST. I'm very happy with the quality of all the parts including the RAM clutch and the DynoTech driveshaft. Their adjustable crossmember was top notch too. There were several things I upgraded on my own tho, like the fluid reservoir, shifter boot, lever, etc. Small things. I made sure also to get all ARP fasteners for things like the flywheel (from SST).
      Nov 2010
      Ventura County CA
      Thank you for the feedback! Much appreciated.
      Clint,
      That's basically the same parts that I bought for the GTO. Been very happy with the setup.
      Feb 2016
      Lawrenceville, IL
      Craig,
      Yes, we use a billet angle adapter with the firewall plate to get the push rod alignment set correctly when using a Tilton or Wilwood master. It looks like this when put together.
      Name:  bowler-1967-1969-gm-f-body-hydraulic-master-cylinder-kit_fae8a04e-35da-45f4-b043-c5b0ac3ae6eb_18.jpg
      I like that arrangement! What's the stroke of that style MC?
