      Sep 2019
      parking light turn signal - daytime running lights
      I am smoothing the front valance and removing the parking light/ turn signal. This will be replaced by a custom housing that will be inset into valance to have a smooth look. While I am at it I would like to convert the parking lights to daytime running lights. The plan would be to use a clear cover and white LED for the daytime running lights. The turn signal would then use amber LED's.
      My question is when the daytime running lights are on and I activate the turn signal, I would need the daytime light on that side to turn off. Any thoughts on how I would accomplish this?
      Oct 2015
      https://hogworkz.com/halomaker-1157-...oogle_shopping
      They make numerous sizes. I have them on my bike. Work great. These do what you're wanting to do.
      Nov 2011
      Wylie, Texas
      That is what a switchback LED bulb will do. As the name implies the bulb is amber while it's blinking and then switches back to white when the signal is cancelled.
      Atlanta, GA
      Here's what I used- Flexible strip lighting
      I like them as they have a smooth look- and don't see the individual LEDs.
      I used a 24"-AND you can cut them to size- have two inputs- turn (amber) and parking (or daytime running)
      Jun 2011
      Brooklyn, NY
      I used those LED strips too on my '71
      Boonville, Missouri
      Nice use of the products out there. The only questionable part is holding up the heat and the elements (keeping them sealed up)
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
