      Feb 2014
      Twist Machine Paddle Shifter
      Hi,
      I was I wondering if anybody has had any experience wiring the Twist machine paddle shifter to the holley dominator.
      Attached are the Twist Mahine instructions for the Compushift controller...I'm uncertain as to where to connect the white common wire to the dominator.
      Any help is appreciated.
      http://www.twistmachine.com/content/...stallation.pdf
      thanks!ShrifterInstallation.pdf
      Quote Originally Posted by BlackHD View Post
      Hi,
      I don't know this for a fact, so that that for what it is worth, but my guess is that the white (common) wire should go to one of the Dominator sensor ground pins. Consult the Dominator pin-out map, as there are multiple available sensor grounds on all of the Dominator connectors.
      Sep 2016
      Atlanta
      what transmission are you controlling ?
      Feb 2014
      Hi Andrew, so it would be an sensor ground "output" from the dominator?
      thanks for your help.
      Hey WOLF1732, its a 4l80e.
      Yes, but again, this is purely speculation.
      Feb 2014
      Great thanks, I'll give it a shot.
      Also, I do remote Holley EFI tuning and can consult on other wiring issues. Shoot me a PM if I can be of service.
