    Results 1 to 10 of 10
      Apr 2014
      JAPAN
      Country Flag: Japan
      ridetech CoilOver System
      I installed a CoilOver System on the 1969 Mustang. Do you have a matching minitub?Name:  IMG_0750.jpg
      Mountain Springs, Texas
      Detroit Speed has minitubs for that car.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Apr 2014
      JAPAN
      Country Flag: Japan
      Don
      There was an explanation that the Minitro of Detroit Speed ​​cuts the frame. ridetech's coil over mount is attached to the frame.
      thank you
      Lawrenceburg, TN
      Quote Originally Posted by Shotaro View Post
      thank you
      the mini tub kit only removes part of the frame rail... the outer part the ridetech cradle mount to the inner... you only have to cut a little part of the ridetech cradle
      here is a picture of the narrowed frame rail and the ridetech cradle as you see only a little trim work need to happen...... p.s. don't forget well the tubs and members her get a 10% discount
      Dec 2009
      San Diego, CA
      Another option is to use the Detroit Speed kit, but not do the full mini-tub. What I mean is to cut out the sheet metal only to the factory frame rail. But if you do this, maybe it would be cheaper to buy a factory reproduction wheel tub, cut the factory tub out, leaving a 1"-1.5" lip (the distance really should from the factory inner wheel tub to frame rail) for the reproduction wheel tub to butt-weld to. The downside, you can't fit as big a tire if you did the full mini-tub.
      Robert Icasas
      Projects:
      67 Cougar
      Art Morrison Sport IFS
      3-link Rear Suspension
      Coyote w/ D&D Performance Viper t56
      Jan 2013
      ST George UT
      That frame rail in the picture looks bent about 3” before Ridetech upper link bracket.
      Apr 2014
      JAPAN
      Country Flag: Japan
      Quote Originally Posted by classiccarcustoms View Post
      That frame rail in the picture looks bent about 3” before ridetech upper link bracket.
      Thank you very much. But I don't want to cut the frame.
      Jul 2010
      Harrisburg, PA
      If you want to widen the tub just to meet the rail you are still going to have to also relocate the lower link bars. Since the bar attached to where the leaf spring went on the outer side of the frame rail.
      Joshua O
      Aug 2017
      South Dakota
      I have the Ride Tech coil over system on my car a 1970 mach 1 and I made my own mini tub. I made the tub square and went to the frame rail but did not cut it. I did this as it was the max I could go and still keep the rear seat without having to modify it. My wheel wells can handle 315-325 tires with ease but the lower 4 link bars on the ride tech system are the limiter. I have 305's on the car now and should be able to go to a 315 wide tire but the suspension is the limiting factor.
      Apr 2014
      JAPAN
      Country Flag: Japan
      Quote Originally Posted by builttodrive View Post
      Is it possible to send me the attached photo? I'm thinking of buying a Detroit Speedo minitab.
