      Feb 2014
      SoCal
      Sound deadening on deck lid
      I’m just about done laying dynamat extreme throughout the trunk but am on the fence about putting on underside of deck lid because it’s obviously painted and looks nice. Will it damage paint if I want to remove one day? What do you guys do? Leave it bare or put it on the recessed part of lid? Thank you
      Milwaukee, WI USA
      Doing the underside of the trunk lid is overkill. IMO.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Feb 2019
      Kankakee IL
      Perhaps do a liquid sound dampening material through the various openings and flow it around and it will never be seen?
      Tracey
      Depends on how big the subwoofer is in the trunk :-)
      Aug 2010
      Seattle area
      The trunk floor yes the trunk lid no.
      Jan 2014
      Portsmouth NH
      I did my trunk floor this winter and NOT my trunk lid. Driving the car this spring I can say it made a difference.
      Oct 2014
      DFW, Texas
      I wouldn't bother, focus more on keeping the noise that is in the trunk, in the trunk and not in the passenger compartment. You can do some nicely cut mass loaded vinyl if you just gotta have something, and it will look pretty decent.
      Depending on the car, that means focus on the backseat closeout and package tray.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Orange County, CA
      Once you apply dynamat you can pretty much consider it permanent, so wait if you’re not sure if you want it. What you could do is install a few small pieces of dynamat in the recesses like you mentioned, then have an upholstery shop make carpet, or some other material, inserts to go in the recesses and cover the dynamat. It would look good and cut down on vibrations.
