      Oct 2009
      Help finding correct terminal
      Hello i have a PSI harness and i need to shorten the alternator plug. Does anyone know what female wire terminal i need?
      Pics belowName:  IMG_3799.jpg
      Thank you
      Ps i did email psi with no response as of yet
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Apr 2018
      Its a bosch brand connector 1928403137. Uses TE/Tyco terminals, Junior-Power-Timer is the series.
      https://www.automotive-connectors.co..._store=english
      Should be able to use that page for terminal part numbers. Tyco 929940-3 or 929930-3 or equivalent will fit. I have terminals and seals that fit that connector if you have trouble sourcing.
      Oct 2009
      Thank you!
      LS3
      Feb 2019
      Kankakee IL
      Andrew B on here is the terminal God. He's the guy I'd ask.
      Tracey
      Oct 2009
      I feel like the psi harness is mad long. Im gonna need to shorten a bunch of sensor wires like the acc pedal and cam/alt sensors just so the wires will be tucked a little better
      LS3
      Quote Originally Posted by ween View Post
      This is solid information...
      https://www.mouser.com/ProductDetail...iABEgJnYfD_BwE
