    Results 1 to 9 of 9
      Jun 2013
      Central FL
      If it's a plug and play type kit and you follow the instructions you should be okay. Things like lights and all are very straightforward to wire. On sensors sometimes you need special grounding or shielding but if you buy a reputable kit that's taken care of for you.
      If you're willing to give it a shot you can save some money. Just watch some videos before you decide, see if you can make sense of the schematics. If you can read those you'll be fine. After you make every crimp tug on the wire to make sure it doesn't pull loose and you'll avoid chasing intermittent issues.
      James
      1969 Mustang Fastback
