      NJ
      MSD Solid State Relays
      Anyone using them? Seems like a clean solution, four channels per module rated at 20 amps each and can be bridged for higher loads.
      Just wondering if anyone is running these or knows any more info on them.
      Sep 2016
      Bakersfield, CA
      I am using it for the electric fans on my C&R but an going to a PMU for everything this summer: https://www.holley.com/products/data...ts/500-KT-SWST
      The SS relay has been working just fine tho.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      NJ
      Glad to hear they've been working fine. I planned on getting one to control the dual fans on the radiator.
      I also came across this on YouTube and they look pretty slick. Won't be available until the end of the year though.
      https://youtu.be/KLv7gQ6Milo
      Oct 2018
      Phoenix, AZ
      Those new Kaizenspeed relays are potentially huge for pro touring. With the small CAN module you can add for minimal money it opens the doors up for us to really modernize and further integrate electrical systems into these older cars.
      I am currently about to install the Smartwire kit linked above, but will be doing those new relays, when they are released, on another project.
      I haven't ever seen anything negative about the MSD SS relays for the record.
