    Results 1 to 14 of 14
      Feb 2013
      You should probably be running an Accumsump if you are tracking the car.
      https://www.dragzine.com/news/canton...-does-it-work/
      Yes I definitely agree with you and didn’t run one before because I thought with my road race trap door baffled pan, large volume, and cooler I would be ok. I have a friend who conveniently has a spare accusump that he took off another car that he is giving me and I will for sure be running one for piece of mind. Also will most likely wire up a dummy light for oil pressure as you can always watch the gauges. I think that’s a good fix but also think this should not have happened as quickley as it did with an engine that was supposedly built to handle it. Now just looking for ideas on what could cause bearing failure under road race conditions that I haven’t already addressed. Thanks for your time guys keep em coming if you have ideas.
