      Mesa, AZ
      Rag Joint Eliminator
      I have searched and searched and found nothing. Is there a universal joint that will eliminate the stock rag joint on my 68 firebird? Or is it accepdable to run the rag joint at an angle? Thanks!
      -Dennis
      Try Flaming River. They will have a needle bearing U-joint that will work.
      Mesa, AZ
      I took the steering column out but I cant see how the fitting on the column is supposed to come off...there are no bolts and I cant pry it off. Am I missing something here? i am reluctant to bust out the torch for heat. Should it just slide off the column shaft or is it connected?
