      Sep 2017
      LS3 Holley Oil Pan
      Since the Chevelle requires a different oil pan, I did buy a Holley pan. The paperwork that came with the cruise and connect kit says the stock motor/pan takes 8 litres. The Holley pan is shallower so it clears the cross member. I'm assuming the amount of oil required doesn't change?
      Thanks in advance,
      Perry
      Pensacola, FL
      The paperwork that came w the holley pan should have the specs/capacity, oil filter part # etc.
      Jacksonville, FL
      Yeah, Holley pan is I believe 6 qts. I have the 302-2 pan.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Oct 2019
      The pan dictates the amount of oil, not the engine. And beware - your dipstick will no longer read properly unless you’ve also purchased a matching dipstick.
      Sep 2017
      Thanks for making me check haha. GM's website sells the Holley 302-2 oil pan for the LS conversion and in there they said I will need GM part #12669528 dipstick which is what my LS3 has.
      Oct 2015
      Quote Originally Posted by Cavi Mike View Post
      Shouldn’t the oil level end up where it was originally regardless of the pan being used? Thus, the original dipstick would work.
      I have the 302-2 pan with a stock dipstick and believe it’s stock, unless it is remarked or something. It’s been quite a while.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Sep 2017
      I just went through my first start after 2.5 years with great success. Having said that, the stock dipstick works perfectly with the Holley oil pan. After filling the filter with oil and adding 6 litres for the engine, I checked the oil level and it was right at the upper level on the dipstick.
