    Results 1 to 20 of 24
      Jun 2017
      Idaho
      LS swap oil pans...
      Looking for opinions and expertise on oil pans. I'm using the AME GT Sport front clip in a 69 Camaro and installing a 2013 ZL1 LSA. Stock oil pan definitely isn't going to fit and my question is between the Chevrolet performance pan and the Holley variants is there any issues with the GM pan? It is $100 cheaper than the Holley ones. Is it worth spending the extra Benjamin on the Holley?
      Beach Park IL
      The GM swap pan is great if you prefer the oil pan to be the first part of your car that drags on the ground.
      Donny
      Mountain Springs, Texas
      the gm swap pan is great if you prefer the oil pan to be the first part of your car that drags on the ground.
      lol...
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jun 2017
      Idaho
      That is a good point...I suppose I'm going to need to remove the pan and set the motor in place to determine the max depth the pan can be before extending past the crossmember....
      Feb 2018
      Southern IN
      Four words...Mast Motorsports oil pan.
      More ground clearance then Holley.
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Jun 2017
      Idaho
      Quote Originally Posted by Gmachine1911 View Post
      That pan is even more expensive than the Holley...what makes it worth a $100 more?
      Beach Park IL
      Not sure why this didn't post before. But 5.75" is more than 5.69" It is entirely possible that someone fibbed on their dimensions but I would say they are close enough to be a wash. I am aware of the provisions for the oil cooler on the Mast pan but that doesn't address the thermostat.
      Donny
      And it looks like they're just comparing Mast to the Holley 302-1. But the 302-2 has more ground clearance by 0.29". Whether or not that matters, I don't know.
      Quote Originally Posted by Snowcatter View Post
      A little late, but the Mast includes a baffle kit. Holley you have to buy it separately (and they're pretty expensive - $200+).
      Beach Park IL
      Care to back that up? With actual measurements?
      There are some things that the Mast pan does better but I prefer the Holley pan with the bellhousing mounts built in and the ability to use the Earls thermostat for the oil cooler.
      Donny
      Feb 2018
      Southern IN
      No, I don’t mind backing that up at all...and btw, the Mast pan also has oil cooler provisions built in. Name:  5E1FD49B-2334-401D-8B3A-B8644A7E1741.jpeg
      Shane
      #theanchorholds
      Jun 2017
      Idaho
      Does the stock ZL1 LSA oil cooler work with the Holley pan?
      What pan does AME recommend with their front clip? Shouldn't they know what works best?
      Jun 2017
      Idaho
      From AME installation instructions:
      Oil Pan Selection
      The engine oil pan design is critical for proper performance as well as trouble-
      free installation. The location of the steering rack only allows the use of oil pans
      that replicate the stock profile under the number one and two cylinders. The use
      of fabricated aluminum or a highly modified pan may cause interference and
      require notching for proper fit.
      The F-Body LS oil pan has been tested and approved for sufficient clearance;
      GTO, Corvette and truck pans utilize similar front profiles but should be test-fitted
      prior to final installation. C5 “batwing” pans should be avoided as they will
      interfere with headers.
      They mention the F-body LS pan but I'm not sure which pan specifically they are referring to????
      Jun 2013
      West Blocton, Al
      typically the "F body ls pan" refers to gen 4 LS pan 98-02
      Quote Originally Posted by silo84 View Post
      I would agree with the above statement. The Holley 302-2 and 302-3 pans offer even more clearance in the rack area than a 4th gen F-body pan and have a slightly shorter (lengthwise) sump, so they should work very well for you. The Holley 302-3 offers clearance for a stroker crank and also has two, cast ports for turbo drains, in case that is something of a consideration for the future.
      Jun 2017
      Idaho
      Thanks everyone for your help...I am leaning towards the Holley 302-1 because the sump is much more rearward and my initial fitment of the motor appears that the 302-2 profile will hit the crossmember. I will definitely be posting pictures of it for future reference once I get it installed. I do want to look into that F-body pan as well to compare the profiles.
      Jun 2017
      Idaho
      So after comparing all the LS oil pan options available from Holley, Mast and GM I discovered that the LSA engine I the Cadillac CTS-V has a profile very close to the F-body pan plus it has the mounting provisions for the oil cooler which make this an obvious winner for my application. Also it is much cheaper than the Holley ones. I can order the pan, dipstick and tube, pickup tube, and gasket for less than just the Holley pan. I am ordering this now and will post pictures of the fitment as soon as I get it installed.Name:  Screenshot_20191030-083218~2.jpeg
      It's deeper than the f body pan. Ten bucks says it will hang below the front cross member. I wouldn't be comfortable with that.
      Jun 2017
      Idaho
      It is 1" deeper and I think I can live with that. It's the oil cooler mounting that is the main reason to go with this pan. Most LS engines don't have the engine mounted oil cooler which is only on LS3 & LSA engines.
