    Results 1 to 9 of 9
      Dec 2008
      Detroit
      Sanding down painted car
      Hello all,
      So my car had some cheapo paint on it done by a dealer to get it off the lot. There are places where the paint is actually flaking off of the car and you can see a smattering of primer and the original color. I would love to be able to sand those areas and start to remove the paint to have to decent surface as i plan to wrap the car for the time being.
      I'm trying to find the recommended grit to start with? I figured I shouldn't be too aggressive with it as I'm not trying to go for bare metal.
      Should I use a flap disc or an orbital sander?
      Any help would be greatly appreciated.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Nov 2010
      Random orbit sander with some 320 should work good, but not be too aggressive.
      Mountain Springs, Texas
      Applying a wrap over paint with adhesion issues might be a little problematic. I would sand all that paint off before attempting the wrap.
      To remove the paint I would try 120 grit. Follow it up with 220 if needed.
      Rather than sand it off you could try scraping it off with razor blades.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Aug 2008
      jacksonville,fl
      For loose areas you can also try lifting weak paint with a strong tape such as duct tape. Rub it on hard & leave a length as a grab handle,
      Dec 2008
      Detroit
      Don
      Yeah, I want to remove the poorly applied paint to get to the original paint which is not flaking. They don't appear to have done anything besides "prime" on top of the original paint and spray.
      - - - Updated - - -
      Quote Originally Posted by Tincup View Post
      Quote Originally Posted by jlcustomz View Post
      Thanks guys, I will start there.
      Chris--
      Oct 2013
      H-Town, TX
      I would think you would go through a lot of 320 discs as it will probably clog up pretty quick. I would use the 120
      Jun 2010
      Deployed
      Quote Originally Posted by 1965gp View Post
      seems pretty aggressive to me, that will easily take you down to metal! I would start with 600.
      1970 Camaro/DSE build
      Oct 2013
      H-Town, TX
      I guess it depends on what kind of paint we are talking about. I was assuming this was a thick single stage paint job
      Dec 2008
      Detroit
      Actually the paint is not thick at all. I'm going to mess with it after I finish my latest winter update to the motor.
      Chris--
