08-15-2019 #1
- Jul 2017
- 167
Turning engine over by hand question
FYI i posted this in the LTX section but there’s not as much traction and this issue is related somewhat to both gens.
I have this concern floating around in the back of my mind about my L86 motor. I inspected the valve train and bottom end to the best of my abilities while I had the valve covers and oil pan off. When I go to turn the motor over by hand with a ratchet wrench there is one area in each revolution that is a little easier to turn than the rest of the turns. This was done with the plugs out and on a motor stand by the way. I'm getting closer to starting the motor for the first time and I wanted to get some thoughts on this. I personally just thought it was the DOD lifters and nothing major because the motor only has 3500 miles and had no know issues prior to being pulled out for my swap. Would the DOD lifters make it feel a little strange/easier to turn the motor by hand if they have no oil pressure going to them?
