    Thread: D100
      Aug 2019
      D100
      Hello all I have a 1976 dodge d100 long bed 2wd right now with a /6 3 on the tree, going to be swapping in a 12v cummins zf6 trans my question is I want to bring it closer to earth and more protouring I want a rack and pinion front end with 4 wheel disc and a irs rear so I’m asking everyone here what irs and ifs to use and anyone done this before so any info help be great tks
      Nov 2010
      You do realize that a 6bt Cummins weighs in at about 1000lbs.....
      Oct 2018
      Phoenix, AZ
      I am with Tincup in making sure you recognize how HEAVY that engine is compared to all the V8s around here. It's about double the weight. You'll need a very robust front suspension. Probably something like No Limit's wide ride with additional frame reinforcements. For IRS there is endless options, but they all require a decent amount of fabrication. You'll also need to be picky here since you'll be pushing far more torque than most IRS diffs can take repeatedly. I'm personally doing the 2015+ mustang gt IRS which is a great option for the money.
      If you haven't seen it before, look up Old Smoky F1 which was built and is currently raced by Chuckles Garage. He has a fully built version of that motor in a very capable F100 race truck. That might help you get a feel for what it takes to hold that lump together around corners.
    Tags for this Thread
