    Results 1 to 11 of 11
      Jul 2018
      Proforged TALL upper ball joints.... GAP???
      Anyone installed the proforged tall upper bj's? Is there supposed to be a gap like this? I'm pretty sure it's supposed to be this way
      20190320_180331 by F G, on Flickr
      20190320_180348_001 by F G, on Flickr
      Michigan
      Yes, that's now they're supposed to look.
      - Ryan
      Oct 2014
      DFW, Texas
      Looks "tall" to me.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      May 2011
      Chippewa Falls, WI
      no issues, that is normal. The only critial area is to know the tapered seat is torqued and tightened properly and this is for your spindle application.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Jul 2018
      Quote Originally Posted by Typhoon1015 View Post
      I Tightened till the bolt broke then backed off half a turn
      Oct 2011
      Philipsburg, Pa
      It is 100% supposed to be like that. You're good to go.
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
      Shmere some anti-seize on the exposed shank to keep it from rusting.
      Central CA USA
      I cut a piece of heater hose and slip it over the stud shank before installing. Put some grease on the stud first.
      Jul 2018
      David, I wish I would have thought about that before I installed them. Not sure i want to take it back apart to do it. A little antisieze will probably be the thing for now.
      Since they are already installed, maybe spit the rubber hose to wrap it around and sacrifice a couplt tie wraps to keep it in plance? I did the heater hose since I didn't want the boot to drift and uncover the ball and socket
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2018
      I thought about that, I did go ahead and coat them real good with anti seize.
