    Results 1 to 17 of 17
      Sep 2016
      Bakersfield, CA
      Help with my battery relocation please
      1969 Firebird. First off, I'm really a dumb simpleton and a total newb when it comes to electrical, so when helping PLEASE spell it out for me like I'm a child. I need to get my sh*t in order before my car burns down. I want to do everything right (correcting what the previous owner did) and the first step in that will be relocating the battery to my trunk behind the rear passenger seat (I need the space under the hood).
      I have read the battery relocation sticky and it helped tremendously to get me this far. Now I just need to tweak it for my setup.
      I'm running a ton of modern stuff that needs GOOD power: Dakota VHX gauges, Dakota digital fan controller, dual electric radiator fans, VintageAir A/C & heater, fans on my transmission & oil coolers, LED headlights & all LED bulbs everywhere else all over the car, Holley Terminator Stealth EFI & fuel pump, and eventually I'll add a mild stereo system. Also, I live in the CA desert where it can be 125F, stuck in traffic, with literally ALL of that running simultaneously. Only thing I don't have is an electric water pump and power windows.
      Here are the parts I already have:
      New 1 wire alternator (replacing my externally regulated alt) - already installed
      Odyssey battery, NHRA Moroso battery box w/pad (NHRA)
      Pollak battery disconnect switch (NHRA) w/pigtail to keep power to the radio - mounted on tail panel
      Remote starter solenoid - currently on the radiator support
      New ground cables: Battery to the body, body to engine, & body to the radiator support. All are 1/0 gauge in black.
      My buy list:
      Power distribution block
      200 amp fuse
      3/8" bolt hardware to mount battery box
      4 gauge welding wire
      Currently, the previous owner has installed a starter solenoid as a distribution block on the radiator support on the driver's side. Alternator wire goes to it, from it goes a wire to the battery and another to the starter (2 other small wires too). The electric fans have relays and fuses but are wired to the battery instead of this solenoid/distribution point for optimal alternator amp draw like I think they should be.
      I plan on relocating the solenoid to use in the trunk by the battery, so I'll go battery + to the solenoid. I've heard that doing this is great because then the big cable going under the car to the front is only energized during starting. Correct? Where is the best place to put the fuse for the system?
      I then plan on installing a proper distribution block on the firewall where the external voltage regulator currently is. Then I'll wire the alternator to the distribution block. To this distribution block, I'll connect the electric fans and main power for the fuse box. From the fuse block, I have my digital gauges, fuel pump, etc. wired. My Holley goes straight to the battery + as instructed.
      My questions:
      1): Wiring the solenoid so the cable going up front is only hot during crank. How exactly? I have attached a picture of it. Like what cables from where should go to which terminals on it?
      2): Wiring up the starter. How exactly? From where to where? I'm not exactly how this work with a remote solenoid.
      3): Wiring in the disconnect switch. How exactly? I have attached a picture of it. Like what cables from where should go to which terminals on it?
      4): I have ZERO clue how that pigtail on the disconnect switch wires so my radio remembers it's presets, but I figure I'll cross that bridge when I upgrade my stereo lol.
      Once I can get a diagram drawn up for my exact configuration, then I can order the cabling, connectors, tools, and other parts I need to start going to town. I've decided to invest in a heat gun and crimpers and learning to do it all myself.
      Thanks!!!!
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
