Results 21 to 24 of 24
01-05-2006 #21
Man for out here in San Jose that is cheap for machine work...
I expected my 383 w/6" rods to need some mallory metal, but it balanced out without Mallory. Maybe I'm lucky, or maybe my machinest is just more detail oriented than most.
Just call me Brett
01-05-2006 #22
- Aug 2004
- Clovis, Ca
- 109
Most of the aftermarket "383" cranks will internal ballance if you keep the bob weight under around 1850g. If you use a reasonable weight 6" rod (600-650g) and a forged piston (around 525-545g w/pin) you should be able to internal ballance the crank. You should check with the crank MFG before you purchase and check what the bob weight their cranks will ballance to.
You will "usually" get a lighter bob weight with a 6" rod due to the fact that a piston for a 6" rod 383 is lighter than a piston for a 5.7" rod motor. The recprocating and rotational weight of the 6" rod is a little more than the 5.7" rod but the lighter piston usually is more than enough to offset the additional rod weight.
Another reason to look at using 6" rod is some of the "383" cranks out there have counter weights too large for the 5.7" rod and the piston will hit the counter weight.
Internal ballance is better on bearing durability and like was stated before, if you have the crank internally ballanced, you can change flywheels etc. with out reballancing.
If you are building a motor from scratch, you should work with you engine builder and decide what you want to do and purchase the correct parts so you don't run into problems
Dave
01-06-2006 #23
