Results 1 to 20 of 24
12-10-2005 #1
383 Internally or Externally Balanced???
I searched for this answer in past posts , but could not find the answer.
I am doing my homework in preparation to building a 383 for my 69 Camaro. I will be running a Muncie 4speed.
I see all the lower priced rotating assemblies are externally balanced and use a flexplate for an auto trans.
If you are running a manual trans do you have to use an internally balaced kit?
Goal for the motor is 430hp.
I was thinking about buying a crate motor but I want the ppride of having built my own motor.
Thank you for the input.
12-10-2005 #2While I am thinking about it. What is best the 6" rods or 5.7?
What is the difference?
12-10-2005 #3Internally balanced assembly. The flywheel comes balanced. Why? I have no idea but that is what I learned from my car (T56).
12-10-2005 #4
- May 2005
- 408
internal / external balance
Kits usually come balanced for an automatic. You can buy a light weight flywheel that is counterbalanced for a 400 which is what a 383 is essentially. Or an engine shop that balances engines can help you if you
want to use a standard flywheel. The 383 can be balanced internally but is expensive because the mallory metal that they use is expensive. I may have spelled the word "mallory" wrong.
12-10-2005 #5
- May 2005
- 408
balance
Use the 400 balancer. The 400 and 454 were external balanced
engines. Use the 5.7 or 6 inch rods. Scoggins and Dickey in
Texas has the best deal on stroker kits.
Billy
12-10-2005 #6
- Aug 2004
- Colorado
- 397
